condensation in rear lights
Old Feb 25, 2002 | 06:55 PM
flymecourageously's Avatar
New User
Default condensation in rear lights
what causes this and how can i fix it to prevent it from happening thanx
Old Feb 25, 2002 | 08:41 PM
GoodFella's Avatar
Unfortunate Clevland Sports Fan
Default Re: condensation in rear lights (flymecourageously)
same thing with me....i need to know how to fix it also....the only thing i can think of is pop it open use a heat lamp to dry it out and use a good sealent to close it back up
Old Feb 25, 2002 | 08:46 PM
wizurd's Avatar
Just a crappy or old seal around the housing. Could try opening it a little and drying it out with a blow dryer or in the sun.
Old Feb 25, 2002 | 09:59 PM
iluznxpnoi's Avatar
New User
Default Re: condensation in rear lights (wizurd)
reseal it with black silicon adhesive sealent or something like that...most likely theres a crack or the seal has a hole somewhere..do the seal all over again
[Modified by iluznxpnoi, 7:07 AM 2/26/2002]
Old Feb 25, 2002 | 10:05 PM
wizurd's Avatar
Default Re: condensation in rear lights (iluznxpnoi)
Did you say reseal it with a ****? Dude....that stuff is sticky....but c'mon now.
Old Feb 25, 2002 | 10:08 PM
iluznxpnoi's Avatar
New User
modified^^^ you can get the black silicone adhesive sealent at kragen or so
Old Feb 26, 2002 | 12:29 AM
Gump's Avatar
had this problem with my old 95 coupe, just take off the taillights and get a blow dryer and dry it out, i did this and it never happened again
[Modified by xlr8 si, 12:38 PM 2/26/2002]
Old Feb 26, 2002 | 11:25 AM
Integra97Zeke's Avatar
sometime if you dont tighten the bolts up enough it can cause the condesation.
Old Feb 27, 2002 | 12:50 PM
nerdish's Avatar
Default Re: condensation in rear lights (IntegraZeke)
This happened to my 94 GSR.
First try drying them out real well. If the condensation comes back try buying new taillight gaskets from http://www.ahmotor.com. And then make sure you screw everything back in TIGHT!
Should do the trick.
Now I just have to get water out of my headlights.
infulleffect
Northeast (Sales)
Mar 11, 2012 04:26 PM
97civicsedan
Jun 27, 2005 12:18 AM
honda_S
Mar 6, 2004 03:16 PM
DRxCIVIC
Sep 13, 2002 05:16 PM
mr_mbuna
Aug 24, 2002 04:28 PM
