compression is low on one cylinder....#2 is 150 psi
Old Aug 31, 2005 | 02:23 PM
ndlyng's Avatar
Default compression is low on one cylinder....#2 is 150 psi
I did a compression test on my 99 gsr hatch and it is #1-200 psi, #2-150psi, #3-210psi, #4-200psi. I think #1 is closest to timing belt and so on. Before this test my radiator hose cracked and all my fluid went out. The engine was overheating for 30 minutes. I fixed the problem. Anyways, do you guys think it is my piston rings or my head gasket? If rings, should I replace just the rings? If head gasket, should I replace it with an aftermarket HG?
Old Aug 31, 2005 | 05:17 PM
Runnerdown's Avatar
Default Re: compression is low on one cylinder....#2 is 150 psi (ndlyng)
If it got that hot, head/head gasket is the place to look. Only a teardown and close inspection will reveal the exact problem. Make sure to check the head and deck for warping with a straight edge and feeler gauge. Or if you don't have access to that, have a good machine shop check it out.
Old Aug 31, 2005 | 05:53 PM
onepoint6i's Avatar
Default Re: compression is low on one cylinder....#2 is 150 psi (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndlyng &raquo;</TD></TR><TR><TD CLASS="quote">I did a compression test on my 99 gsr hatch and it is #1-200 psi, #2-150psi, #3-210psi, #4-200psi. I think #1 is closest to timing belt and so on. Before this test my radiator hose cracked and all my fluid went out. The engine was overheating for 30 minutes. I fixed the problem. Anyways, do you guys think it is my piston rings or my head gasket? If rings, should I replace just the rings? If head gasket, should I replace it with an aftermarket HG?</TD></TR></TABLE>
more than likely head gasket, but you might have some valves not seating right in that cylinder.. I would do a leak down to make sure, if you have no access to a leak down tester, have a shop do it.....Or you could just drive around like normal, if it starts heating up and giving you starting trouble its your HG; if not then more than likely its your valves not your piston rings....Also check under your oil cap for choclate= water/coolant mixed..
wayneDOHC
Sep 18, 2013 03:39 AM
jdmek2277
11
Sep 9, 2008 07:44 PM
krazeenoy
Jul 3, 2007 06:39 AM
BLK99VTECR
Dec 25, 2005 09:27 PM
2fast4u831
17
Aug 29, 2004 02:29 AM
