Catch can question!
Old Aug 31, 2005 | 01:42 PM
efficiencyJunkie's Avatar
Default Catch can question!
Hey guys,
I have a f22b in my 94 accord (engine is stock.) I put in a Greddy catch can recently and noticed with the clear lines it comes with a small coating of oil coming from the engine to the catch can, and also the line coming from the can back to the intake.
I know that I need a new valve cover gasket, along with grommets, but can this mean a larger problem? My car does have almost 200k, so this was more of a experiment to see if the catch can will do anything. Opened, the catch can is empty.
Thanks!
Old Aug 31, 2005 | 04:41 PM
01usjdmr's Avatar
That is normal, especially with high milage. Those clear lines will probably harden soon too. If you have good compression and leak down #s, I would not worry.
Old Nov 15, 2005 | 11:19 AM
FERIOkid's Avatar
Default Re: (01usjdmr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01usjdmr &raquo;</TD></TR><TR><TD CLASS="quote">That is normal, especially with high milage. Those clear lines will probably harden soon too. If you have good compression and leak down #s, I would not worry.</TD></TR></TABLE>
i have the same problem my compression and leakdown numbers are the same but i seem to burn lots of oil like .25quart in 300 miles
My setup: (sorry for jacking the thread)
USDM B18B1 (about 6-7k on new build)
-eagle forged H-beam rods
-je forged pistons (9:1CR)
-ACL main and rod bearings
-ARP Rod Bolts and Head Studs
-Balanced rotating assembly
-Exedy stage 2 pressure plate with 3 puck sprung clutch
-Apexi World Sport II
-Exhaust and intake ports all gasket matched
-All new Gaskets and seals
-AEM Short ram intake
-AEM Fuel Pressure Regulator
-B&M Fuel Pressure Guage
-Dual core radiator
-Wire tuck
-Engine bay painted flat black
building a turbo kit for it
Old Nov 15, 2005 | 11:32 AM
Sahwn's Avatar
Default Re: (I :heart: 4 DOORS)
did you tune your car before you drove it? Might have ring or valve issues if not.
97grnrs
Aug 22, 2006 10:55 AM
ac_attak
May 25, 2006 02:33 PM
Sport_Injected
Oct 9, 2004 03:09 AM
turbotime
Oct 8, 2004 07:45 AM
MIZIKETSK
Jan 19, 2004 06:17 PM
