rear disk question
Old Aug 31, 2005 | 09:46 AM
Baggy Spandex's Avatar
Default rear disk question
Will DA Integra rear disks work on an eg hatch? I heard from some that it will and heard that it wont...i know youd prob. have to keep the eg compensator arm and whatnot...
Old Aug 31, 2005 | 11:54 AM
Default Re: rear disk question (OneFiveAlive)
Old Aug 31, 2005 | 12:35 PM
rk's Avatar
rk
yes DA rear disk trailing arm/hub botls onto EG hatch.
Then get a 15/16" master cylinder and 40/40 integra prop valve and your good to go
Old Aug 31, 2005 | 12:38 PM
SkoundrelUSA's Avatar
cute little bastard
My friend bought a 92 LS for like 300 and put the rear disc from it onto his EG
Old Aug 31, 2005 | 01:54 PM
BlueIntegraBoy's Avatar
Default Re: rear disk question (panda_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by panda_si &raquo;</TD></TR><TR><TD CLASS="quote">yes DA rear disk trailing arm/hub botls onto EG hatch.
Then get a 15/16" master cylinder and 40/40 integra prop valve and your good to go </TD></TR></TABLE>
There's no need for a larger MC if the front brakes are still stock. A 3040 prop valve would help. I am running rear discs with a 13/15" MC and the stock 3030 prop valve and the stopping is still the same as the drums. I have a 15/16" MC and 4040 PV laying around waiting to put on as soon as I get front Integra brakes.
The only difference between the DA rear discs and other rear discs is the trailing arm bushing, which is larger. Other than that, it will bolt up regardless.
Old Aug 31, 2005 | 02:11 PM
unknown0001's Avatar
Default Re: rear disk question (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
There's no need for a larger MC if the front brakes are still stock. A 3040 prop valve would help. I am running rear discs with a 13/15" MC and the stock 3030 prop valve and the stopping is still the same as the drums. I have a 15/16" MC and 4040 PV laying around waiting to put on as soon as I get front Integra brakes</TD></TR></TABLE>
You can use the stock one...but an upgrade is recomended. I said get the 15/16" MC since you dont need an integra brake booster or MC, and the 15/16" will bolt onto the stock EG BB.
Markb16a
51
Jul 4, 2007 10:36 AM
Markb16a
Oct 14, 2006 01:50 PM
blks2k3
Suspension & Brakes
Jul 17, 2006 09:35 PM
xtreme15
Jun 25, 2005 09:16 AM
The DX Rex
11
May 11, 2005 12:38 PM
