What size bore headgasket
Old Aug 31, 2005 | 08:38 AM
Appleton21's Avatar
Default What size bore headgasket
What size Cometic headgasket would I use with a 84.5 mm bore, on a CRV block??
Are the cometic gaskets listed by the cylinder bore or the bore on the gasket ??
Thanks
Old Aug 31, 2005 | 10:02 AM
THEUSED's Avatar
Default Re: What size bore headgasket (Appleton21)
Its the same number, the bores match, so on a block with a bore of 81 you would use a gasket that has a bore of 81, one with 84.5 youd use a 84.5
Polarshift
K Series
Oct 20, 2017 12:42 PM
onlinehost
Dec 9, 2005 02:40 PM
turbotime
Nov 7, 2005 04:20 AM
asubennett
Feb 3, 2005 07:31 AM
93B17A
Jan 28, 2002 08:42 PM
