i'm seriously going to blow my car up...
ok... i thought the problem was my vtec pressure switch...wrong i was. when i rev (while driving and in neutral) at around 5000-6000 RPMs for some unknown reason i get this cracking noise (like when you touch the postive and negative terminals on the battery together) but if i hold it there, it would sound like a metal saw. no freaking check engine light pops up either~!
You might need a valve lash adjustment.
On my girlfriends 93 Teg, her LS motor was kinda making the same sounds you described.
Durring idle can you hear it? Dose it sound like its right next to the valve cover?
do not have a neat shield... i will go tighten my exhaust bolts...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newark Built Kandy SiC-RX »</TD></TR><TR><TD CLASS="quote">You might need a valve lash adjustment.
i hear it when i'm in the car... i have yet to listen to it outside. can't find anybody to help me revv. here i go outside again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">
get under your hood and push the throttle from there...
</TD></TR></TABLE>get under your hood and push the throttle from there...
Rok_Stok
11
Oct 6, 2010 02:05 PM
