ignition problem when i hit 3500rpm
Old Aug 30, 2005 | 09:51 PM
turboeg77's Avatar
Default ignition problem when i hit 3500rpm
need some help we have a b20 with a vtec head and its having problems with the ignition. when i start the car everything is normal until i rev it up to 3500 thats when the tach goes crazy and the idle goes eratic. when i drive it the car stalls after 3minutes then it wont start for another 2 mins.
we already replaced the distributor, plugs, ecu, main relay, soldered all the connections and still the problem is there. HELP.
Does this have anything to do with the injector relay i just installed. im currently using DSM 450cc's on uberdata
Old Aug 31, 2005 | 07:48 PM
turboeg77's Avatar
Default Re: ignition problem when i hit 3500rpm (turboeg77)
solved the problem. turned out the msd plug wires where the culprit after checking the harness and found nothing wrong we decided to pull the plug wires out and put in the stock wires...problem solved
bochincheboy3ek
Jul 31, 2011 05:28 PM
PR8urVtec
Jan 14, 2011 06:34 AM
GuitarPunk015
Jun 25, 2009 03:24 PM
kDA
May 18, 2006 01:05 PM
turbo sol
14
Dec 12, 2003 01:30 PM
