1992 Civic EX, is it a VTEC motor ??
Im looking into buying a '92 Civic EX and was wondering if all EX models came with VTEC motors or if it was just an option. It does not say VTEC on the top of the engine like I have seen in other Hondas. Thanks for an replies.
buds, why you want ex? get a 92 si hatch, gots better vtech and compression... plus sounds better
. but anyways just do a google on a 92 and all will be revealed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92’si »</TD></TR><TR><TD CLASS="quote">buds, why you want ex? get a 92 si hatch, gots better vtech and compression... plus sounds better
. but anyways just do a google on a 92 and all will be revealed</TD></TR></TABLE>
yep.... si have a higher Tech value....
. but anyways just do a google on a 92 and all will be revealed</TD></TR></TABLE>yep.... si have a higher Tech value....
How the **** does an Si hatch sound better than an EX model? How does it have better compression than the other D16Z6 engines that come in other models, such as the EX, whether it be the Coupe or Sedan?
. but anyways just do a google on a 92 and all will be revealed</TD></TR></TABLE>How the **** does an Si hatch sound better than an EX model? How does it have better compression than the other D16Z6 engines that come in other models, such as the EX, whether it be the Coupe or Sedan?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K SERIES »</TD></TR><TR><TD CLASS="quote">ex models dont start till 93^.</TD></TR></TABLE>
Don't you mean Civic Coupes didn't start until 93.
how about both motors r slow, and u should get a swap on either one u get, so it really doesnt matter which one is faster stock.... as long as u get a vtec car it wont matter which one u get, swap em out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IheartHondas »</TD></TR><TR><TD CLASS="quote">how about both motors r slow, and u should get a swap on either one u get, so it really doesnt matter which one is faster stock.... as long as u get a vtec car it wont matter which one u get, swap em out</TD></TR></TABLE>
MOTOR SWAP is not the answer to everything- Or everyONE, for that matter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screwtape: »</TD></TR><TR><TD CLASS="quote">
MOTOR SWAP is not the answer to everything- Or everyONE, for that matter.</TD></TR></TABLE> sohc vtec kicks ***
Just look for a couple things.
1. the engine code on the block will say D16z6
2. look for the vtec solenoid right by the distributor should have a green plug
3. pull the passanger side kick panel in the car to be sure it has a P28 ECU.
Race my Z6.
Race my Z6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Don't you mean Civic Coupes didn't start until 93.</TD></TR></TABLE>
no the coupe started in 92 but not in a EX model
there are 92 dx coupes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">
there are 92 dx coupes</TD></TR></TABLE>
1992 only had sedans and hatchbacks. The Helms manual published in Sept 91 says 1992 only had hatchbacks and sedans.
wierd my buddy had a 92 civic coupe
yea according to books there was no 92 coupe but his title said it was a 92 dx and it was a coupe
wierd stuff
wierd stuff
Snail Tuning
14
Jan 6, 2021 04:23 PM
