>> Please Help, Axle Nut problem... Can't get it off <<
Look at this, I can't get that middle Axle nut off...
I have the 32MM Axle Nut Socket ( had 34mm but it didnt fit ).
I got this nice Impact wrench and all, and the axle nut doesnt move at all.
What I did to the car .... i basically just too the bolts off of the brake lines that were held onto the arm, if that matters. Also, In the middle of the axle nut there was a bent piece in the middle, I "un-bent" it and all.. any suggestions?
*Yes, it is a integra suspension, I put it in EG cause people read here more and its the same ****
put the tire on and put it on the ground then use a breaker bar with an extension and stand on the extension. it will com off really easy. if you want soak it in wd40 for a little while firsst
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoSlo »</TD></TR><TR><TD CLASS="quote">put the tire on and put it on the ground then use a breaker bar with an extension and stand on the extension. it will com off really easy. if you want soak it in wd40 for a little while firsst</TD></TR></TABLE>
Not if the axle nut has been on for 15 years. Trying to take the axle nut off my friend's 90 Integra, we used a breaker bar with like an 8 ft extension. It snapped the breaker bar.
thanks for all the suggestion, i will try them out after school tomrrow.
once again, i appreciate. More tips anyone?
Oh, and what do you mean "heat is my friend"? Blow torch the bitch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
Not if the axle nut has been on for 15 years. Trying to take the axle nut off my friend's 90 Integra, we used a breaker bar with like an 8 ft extension. It snapped the breaker bar.</TD></TR></TABLE>
use a bigger breaker bar like a 3/4" or 1"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockLee` »</TD></TR><TR><TD CLASS="quote">
Oh, and what do you mean "heat is my friend"? Blow torch the bitch?</TD></TR></TABLE>
Heat expands metal
use a bigger breaker bar like a 3/4" or 1"</TD></TR></TABLE>
Nah, I was planning to swap the whole knuckle (due to new ball joints) to change brakes, but instead we changed just the rotors and pads.
Heat expands metal
soak it in wd40 and let it sit, then spray some more and let it sit. Hit it with the impact and if that doesnt work, get a torch, heat it up for a while and hit it with the impact.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rabius »</TD></TR><TR><TD CLASS="quote">holy hell. i know i dont see a HUGE chunk of the rotor missing... if so, that is... wow. how did that happen?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1300327
if that dont werk then :
not trying to be a smart *** or anything, and I couldn't tell from the pic, you did pry the edge of the axle nut that was tapped down to keep it from turning? just throwing that in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granturismonut2 »</TD></TR><TR><TD CLASS="quote">not trying to be a smart *** or anything, and I couldn't tell from the pic, you did pry the edge of the axle nut that was tapped down to keep it from turning? just throwing that in. </TD></TR></TABLE>
Course, i mentioned that earlier... ill make it go out a bit mroe though just in case ya know
We did the exact same thing. We heated then bolt and then it was easy to take out.
True that. We broke a Craftsman and a Snap-On breaker bar trying to get one of my axle nuts off once. Eventually we just took the hub over to my friends shop where he was able to take it off very easily and for no charge.
i tried all the tips when i did my swap.....in the end i got my dad to drill a hole and chisel the **** out of it.....it relieved the tighness and then i just took a 380 impact gun to it
i was told this thing needed a 1000 ft/lb impact gun to remove at times.
try soaking it in "PB Blaster" , and hitting with a good 600ft-lbs+ impact gun. If that doesn't work try heating it up with a torch.
Thanks for all the tips guys, and .... I managed to get it off!! Easy as pie..
Go to Autozone and they got a Blow Torch kit for like $19.99 lol, WD-40 it then burn the bitch for 3-5 minutes and let the Impact wrench do its job. I was happy when it came off lmao
thanks HT!!
thanks HT!!
pb is the ****...here what i woulda done if my impact couldn't get it off....heat with oxy acetylene till red hot, then hit it with a candle, yes the kind with a wick, then try and zip if off...if that dosen't work, nothing will....couldn't get the nut holding the flywheel to crank off a 13b or whatever you call them mazda rotarys, only thing that worked
dynamo
13
Nov 14, 2005 08:22 PM
EFM_ookie
16
Aug 14, 2005 09:27 PM
