axle not flush wiith transmission case
Old Aug 30, 2005 | 05:25 PM
teewhy55's Avatar
Default axle not flush wiith transmission case
axle not flush wiith transmission case, it sits about 1/4" out of the transmission. my fluid is pretty much empty after 1 week. I tried pushing pretty hard but it doesnt want to go in any further.
Old Aug 30, 2005 | 05:29 PM
jack_attack's Avatar
Default Re: axle not flush wiith transmission case (teewhy55)
make sure it goes in perfectly straight or it will stick out push all you want if its not straight it wont go in
Old Aug 30, 2005 | 05:30 PM
Tyson's Avatar
put a block of wood on the other end and progressively whack the end of the axle to push it in.
Old Aug 30, 2005 | 05:38 PM
teewhy55's Avatar
will that circle clip prevent it from going in? if so, how do you keep the clip flush with the axle?
Old Aug 30, 2005 | 05:42 PM
redryder's Avatar
had the same problem the other day. I noticed the set clip was poking out on one side of shaft. So I put a little more grease on to set the clip in the middle of the shaft, then shuved the shaft in. It took about 10 tries to get it in. At first it was sticking out like yours, but I kept trying. I about gave up, then it went in. So point is, gotta keep trying. I thought at first i got the wrong shaft, but I didnt. Man, now you gotts redo the whole thing, sucks.
Old Aug 30, 2005 | 05:44 PM
Tyson's Avatar
the circlip does create resistance from getting it in the whole way, but its job is to resist the axle from pulling out! so you need that in there as well. just keep trying like redryder said. use more than just your hands.
if you seriously want to get gorilla, separate the lower balljoint and tie rod, and just swing the whole knuckle into the tranny... but a block of wood and hammer will work just fine.
Old Aug 30, 2005 | 06:12 PM
teewhy55's Avatar
Default Re: axle not flush wiith transmission case (Tyson)
well i put some grease to hold the clip centered, slid it in and bang on it with a hammer for a while, honestly thinking of doing the gorilla method...
Old Aug 30, 2005 | 07:10 PM
sam385's Avatar
did the old circlip possibly get left in the diffy?
Old Aug 30, 2005 | 07:21 PM
redryder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teewhy55 &raquo;</TD></TR><TR><TD CLASS="quote">well i put some grease to hold the clip centered, slid it in and bang on it with a hammer for a while, honestly thinking of doing the gorilla method...</TD></TR></TABLE>
i had to do so much extra sht to get mine off, the hell with getting it back in. I had to even take my a-arm anchor bolts out to get the spindle to fall down . My axel was just barely out before i took the anchoe bolts down.
Old Aug 30, 2005 | 07:26 PM
UltimX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">if you seriously want to get gorilla, separate the lower balljoint and tie rod, and just swing the whole knuckle into the tranny... but a block of wood and hammer will work just fine.</TD></TR></TABLE>
This method worked the first time i put it on. i put everything in place and then pushed the knuckle into the shaft. click! it was done.
Old Aug 30, 2005 | 07:41 PM
teewhy55's Avatar
Default Re: axle not flush wiith transmission case (UltimX)
well, the only thing i could see was the end of the axle going into the transmission was getting beat. Im wondering if the bar at the end of the hole in the tranny (differential maybe?) is blocking it or the remanufactured axle splines are too long... anyone ever experience this?
Modified by teewhy55 at 2:57 PM 8/31/2005
Old Aug 30, 2005 | 07:57 PM
redryder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">This method worked the first time i put it on. i put everything in place and then pushed the knuckle into the shaft. click! it was done.</TD></TR></TABLE>
call up another parts place and go and compare. Thats if you got another set of wheels.
Old Aug 30, 2005 | 07:58 PM
redryder's Avatar
Default Re: axle not flush wiith transmission case (redryder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teewhy55 &raquo;</TD></TR><TR><TD CLASS="quote">in the tranny theres a gold ring with 4 notches, but on the axle there is none, might i have the wrong axle?</TD></TR></TABLE>
wrong qoute, i meant to use this one
Old Aug 30, 2005 | 08:52 PM
UltimX's Avatar
You can edit your own posts man. No need to make another one.
Old Aug 31, 2005 | 12:43 PM
teewhy55's Avatar
ttt
Old Aug 31, 2005 | 12:57 PM
civickiller's Avatar
just use more force, i had to hit mine with a hammer to get it in. i also put some oil on it to help it slide in better
Old Aug 31, 2005 | 01:53 PM
teewhy55's Avatar
Default Re: axle not flush wiith transmission case (civickiller)
ive tried hammering it, the inside end of the splines are just getting smashed, but nothing too bad, it still sticks out 1/8"
Old Aug 31, 2005 | 01:57 PM
Tyson's Avatar
do you have the right axles?? did you compare to the old ones?
Old Aug 31, 2005 | 02:37 PM
teewhy55's Avatar
last one i had was sticking out the same, but it too was a remanufactured autozone axle. i seen a post about std axles being listed wrong @ autozone, but i wonder is si axles are too.
Old Sep 1, 2005 | 11:00 AM
do they fit in the hub ?
Old Sep 6, 2005 | 10:40 AM
teewhy55's Avatar
they do fit in the hub, just sticking out about 1/8". Ive came to conclusion something is wrong in tranny, maybe differential
OldSchoolFool
Feb 15, 2023 11:22 AM
Cap'N Chronic
Jun 29, 2011 12:54 PM
B18CYAAA
Aug 11, 2007 04:38 PM
Hoppa
Dec 5, 2006 08:51 AM
law_teg_92_R
Jun 8, 2005 05:16 PM
