How can i run a automatic harness on a manual trans?
Old Aug 30, 2005 | 04:26 PM
ITR.#1446's Avatar
Default How can i run a automatic harness on a manual trans?
I have a 96 civic i am doin a b16 swap into and the person i am doin it for got me a 97 vtec harness but for an auto. How can i make this work? Also it came with a p30 jdm ecu what do i need to run that also?
Old Aug 30, 2005 | 05:45 PM
slomofo's Avatar
GDD Member
The harness is the same, just plug it all in, you'll have two extra plugs for the shift solenoids, just leave those unplugged. You need a jumper harness to run the OBDI P30 ECU.
Old Aug 30, 2005 | 06:11 PM
ITR.#1446's Avatar
Default Re: (slomofo)
how will i have rpms and mph? i think the p30 may be obd2
Old Aug 30, 2005 | 06:16 PM
slomofo's Avatar
GDD Member
Shift solenoids don't control RPM or Speed. Speed sensor still plugs in and so does the distributor, so no worries there.
Old Aug 30, 2005 | 08:33 PM
ITR.#1446's Avatar
oh so it should go on no prob i just have to change the pin on the ecu for the iac?
where are the worries>
xjustblazeitx
Oct 1, 2009 08:56 PM
egb20v
Jun 25, 2009 12:50 PM
slvrslepr
Mar 23, 2009 02:58 PM
ITR.#1446
Aug 30, 2005 06:14 PM
blackstar
Jul 6, 2005 09:50 PM
