Window problem
My drivers side window keeps jumping off it's tracks when i roll my window down all the way or close to it, i have become pretty good at fixing it, but if i'm somewhere without tools, it can be a pain in the @ss. anyone know what the problem may be? any help would be awesome.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx »</TD></TR><TR><TD CLASS="quote">how do i fix it?, i have non power windows</TD></TR></TABLE>Replace the regulator.
your regulator is probably bent, this would cause the window to move in the wrong direction. like they said, remove the door panel and a few 10mm bolts and install a new regulator. you can probably find one cheap on Ebay or your local junkyard.
im replacing mine soon as well, its not hard to do at all.
mine the teeth ground off of it and it wont close fully, but they are very weak designs and can bend easily.
you can get a used one at a junk yard for around 60 bucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan »</TD></TR><TR><TD CLASS="quote">you can get a used one at a junk yard for around 60 bucks
</TD></TR></TABLE>WHOA! New at Honda is $79. You should pay 30-40 tops for used.
don't forget to use silicone paste on the tracks when you replace the regulator.
This will help reduce friction on the window as it goes up/down and puts strain on the motor/regulator.
Yup, here you go.
http://cgi.ebay.com/ebaymotors...QrdZ1
oops thats passenger side you need drivers, well you get the idea.
djfob
May 8, 2006 02:09 PM
.jacob
11
Mar 3, 2003 05:25 AM
