head dissassembly help ....headstuds
Old Aug 30, 2005 | 12:22 PM
allmotor99lude's Avatar
Default head dissassembly help ....headstuds
ive taken the camshafts, bearings, and spark plugs out of my h22a4 (yr1999), and once the camshafts came out, they each revealed 4 circular shaped "bolt heads", but they look round and are fairly large (roughly 15mm). do i need to worry with these or is there something else im missing??? if so, how do i remove them? i need my head completely removed soon. any input would be helpful.
Old Aug 30, 2005 | 12:25 PM
98TypeSH's Avatar
Default Re: head dissassembly help ....headstuds (allmotor99lude)
those are the headbolts.
That would be how you remove the head. Id suggest buying a helms manual before you go any further. They need to be loosened in sequence and in 3 separate steps.
Old Aug 30, 2005 | 01:49 PM
l2yanE's Avatar
if your gonna have the head off take it somewhere and have them resurface and true it, if you do that just take the headbolts out, from the middle and work your way out, any warpage will be corrected by the surface grind, and make sure you use a 12 point socket!!!
Old Aug 31, 2005 | 02:41 AM
Default Re: (l2yanE)
well my problem is the headbolts look completely round (no hex head). how do i remove these with a socket, or is the roundness my imagination? and if so, what size do i need to remove it???
Old Aug 31, 2005 | 04:51 AM
v4lu3s's Avatar
RTFM
if the roundness is not your imagination then you are fucked.
usually you need a 12 point socket to remove those bolts thouhg.
Old Aug 31, 2005 | 05:57 AM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor99lude &raquo;</TD></TR><TR><TD CLASS="quote"> 4 circular shaped "bolt heads"</TD></TR></TABLE>
There should be 10 of them, not 4. Are you looking at the casting plugs maybe? The head bolts are 14mm and 6 or 12 point depending on year. Get a manual, it will be helpful.
brendon.richey
Feb 24, 2013 07:10 PM
Whatislove
Honda Civic (2001 - 2005)
Jun 19, 2010 12:45 PM
hybrid1990crx
Jul 18, 2006 09:17 PM
Firestarter
Nov 5, 2005 01:30 PM
SlowTeg
May 22, 2004 04:11 AM
