Type R axles - are they the same part as GSR axles?
Old Aug 30, 2005 | 05:01 AM
00R101's Avatar
Default Type R axles - are they the same part as GSR axles?
Are Type R front axles the same part #s as GSR axles?
Also anyone know of a source for new OEM axles (other than my Acura dealer)?
TIA
alan
Old Aug 30, 2005 | 06:21 AM
LL2009's Avatar
Default Re: Type R axles - are they the same part as GSR axles? (00R101)
yeah ls,gsr,type r there all the same .
if you have the axles you can rebuilt then is the same as bying new ones
other than that theres a few auto stores in philly that have then .
Old Aug 30, 2005 | 07:58 AM
StageOne's Avatar
You may want to check out raxles.com - http://www.raxles.com/
They have much better prices than OEM and I've heard good results with the people that have used them, many of them racers.
Old Aug 30, 2005 | 09:45 AM
migs's Avatar
Default Re: Type R axles - are they the same part as GSR axles? (StageOne)
94-01 Integra ABS axles are the same
Old Aug 30, 2005 | 10:05 AM
00R101's Avatar
Thanks for the info on RAXLES but I have to use OEM to stay in stock class.
Old Aug 30, 2005 | 10:13 AM
Willard's Avatar
Default Re: Type R axles - are they the same part as GSR axles? (LLEO245)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LLEO245 &raquo;</TD></TR><TR><TD CLASS="quote">yeah ls,gsr,type r there all the same.</TD></TR></TABLE>
Incorrect.
The O.E. ITR axle does not have the rubber 'dampner' ring around it like other axles do.
Old Aug 30, 2005 | 10:32 AM
LL2009's Avatar
Default Re: Type R axles - are they the same part as GSR axles? (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
Incorrect.
who cares about a rubber dampner the question was does it fit and yes it does fit, do your research.
Old Aug 30, 2005 | 10:34 AM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LLEO245 &raquo;</TD></TR><TR><TD CLASS="quote">who cares about a rubber dampner the question was does it fit and yes it does fit, do your research.</TD></TR></TABLE>
idiots that can't read...
the question was not if it fit but are they the same part
now GTFO
Old Aug 30, 2005 | 10:42 AM
LL2009's Avatar
Default Re: Type R axles - are they the same part as GSR axles? (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
now GTFO </TD></TR></TABLE>
the oem axles clearly says will fit any model 94-01 integra including type r
so whos the idiot.
Old Aug 30, 2005 | 10:44 AM
BlueR's Avatar
he didn't ask if it fit
he ask if they were they same part
dense
Old Aug 30, 2005 | 10:45 AM
LL2009's Avatar
ok you gotted due my bad .
japinoyian09
May 6, 2009 11:45 PM
gacraig
16
Oct 26, 2006 05:56 PM
Rishiras
Feb 1, 2005 02:47 PM
TypeRod
Aug 21, 2002 10:48 PM
