B18C5 base, B18B crank, B16A2 head
as been covered before, yes its possible to use the ls crank and rods in the b18c block, just make sure you bend the squirters out of the way of the rotating assembly. it can be done. i have the same setup in my car
Ive heard this before about the squirters, some must bend them, some dont...
I also have a b18a crank in my C block and did have to bend them slightly. Some more than others.
I believe this to be either different counterweight sizing on different model year tegs or manufacturing tolerances(slop). I hate to think its the latter...
Great mod
BTW, how the heck did you break a crankshaft?
Great mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem »</TD></TR><TR><TD CLASS="quote">
Great mod
transportation damage i guess, I got this engine really cheap from a JDM shop,
the crank pulley is moving, what else could cause that except a broken crank
Great mod
</TD></TR></TABLE>transportation damage i guess, I got this engine really cheap from a JDM shop,
I've used a LS crank in a GSR before, and just bent the squirters alittle bit.
The motor ran prefect so I don't know what LS crank your using.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topspeed86 »</TD></TR><TR><TD CLASS="quote">It's not really a good Idea to bend the squirter's the metal is very thin and can possibly break off your better off to plug the squirter's.</TD></TR></TABLE>
its a fine idea. if you bend them too much, sure they can break. if you over torque bolts, sure they can break. If you are assembling a motor, you know what tolerances each material has. I leave the squirters in on the motors i do. why not?
eg4life1202
Jan 11, 2007 04:54 AM
