which ls ecu for 98 honda civic ex
Old Aug 30, 2005 | 02:40 AM
leadtrum's Avatar
Default which ls ecu for 98 honda civic ex
i know i need a p75 odb II, but i've heard there's diff. kinds like an ao-5 or something. i've never ran a regular ecu on my current setup (hondata) and i'm converting it all back to stock.
its a 2000 LS motor in a 98 civic ex. didn't teg's come with immobilizers and should that affect the ecu i buy?
Old Aug 30, 2005 | 04:40 PM
leadtrum's Avatar
Default Re: which ls ecu for 98 honda civic ex (leadtrum)
ttt
Old Aug 30, 2005 | 04:59 PM
eg6ajk's Avatar
what you want is to use a '96-98 spec p75 ECU ('99 is acceptable but not all will work), as the plugs will be compatible and you'll stay with OBDIIa system.
OBDIIb started in '99 uses different plug arrangement as well as immobilizer on some models. this will not plug into the your harness, without a harness converter.
Old Aug 31, 2005 | 09:41 AM
leadtrum's Avatar
Default Re: which ls ecu for 98 honda civic ex (eg6ajk)
so a 99' odb IIa for 65 is a good deal?
PhatBoy5015
33
Oct 29, 2017 11:42 AM
blackccoupe
May 11, 2014 10:05 AM
Sl0wEK
Feb 18, 2009 02:33 PM
BBY98EX
Aug 10, 2006 07:02 PM
