92-95 civic A/C system in 93 delsol?
just wanted to kow if a A/C system from a 92-95 civic will bolt up into 93 delsol..
the parts im talking about are the feed and return lines under the hood, the condendsor, evaporator and fan?
trying to sell these parts and a guy with a del sol wanted to know if they woudl fit.. wantto make sure it foes so i dont sell him wrong parts..
well that should work as well.. since many people seek out A/C compressor brackets from delsols that came with B16 from factory.
but im not selling the bracket.. just all the hard lines, condensor, evaporator and fans.. thats what im hoping that will work but im not sure since the engine bay of the delsol appears to look smaller?:
depends on the year of the civic. 92-93 civics used r-12 and 94-95 used r-134. Other than that, all the lines and condensor are the same.
everything will work...but like someone else said, some tweaking will need to be done. more specifically....the metal lines going to the evaporator (the aluminum can on the driver's side behind the headlight) will have to be slightly bent to go exactly where they need to go. the fan and everything else should bolt right up.
4g4drb17
Oct 4, 2006 12:53 PM
Handle The Business
Aug 17, 2005 10:37 AM
