Y8 Intake Manifold with Teg TB Question
Old Aug 29, 2005 | 05:58 PM
SRCivic97's Avatar
Default Y8 Intake Manifold with Teg TB Question
Ok, I got this Intake Manifold for my auto to manual swap. It's a Y8 manifold with a teg tb but there is one "valve" (smack in the middle of the pic sticking 1 inch out) I guess you could call it that I am unsure what it connects to. Also I think it whistles at certain RPMs.
Old Aug 29, 2005 | 08:25 PM
SRCivic97's Avatar
Default Re: Y8 Intake Manifold with Teg TB Question (SRCivic97)
Bump for an answer 3 hours later maybe?
Old Aug 29, 2005 | 09:44 PM
SloCivicHMM's Avatar
I believe that goes to your charcol canister......
atleast my d15b7 goes to that.....I'm not sure, I"m in my 1st swap stage right now.....just thought I'd give ya an idea...
Old Aug 29, 2005 | 10:05 PM
SRCivic97's Avatar
Default Re: Y8 Intake Manifold with Teg TB Question (SloCivicHMM)
Yeah that was a thought we had too. Although there is already one tube going from the IM to the canister.
Old Aug 29, 2005 | 10:21 PM
underb00steg6's Avatar
are you talking about the sensor or that tube which is some kinda vaccuum that goes to the evap canister?
Old Aug 30, 2005 | 05:53 PM
SRCivic97's Avatar
Default Re: Y8 Intake Manifold with Teg TB Question (underb00steg6)
Yeah I guess that could be it although I already am utiliziing the 2 lines on the canister. The civic Y8 TB doesnt have this tube so Im wondering if I can just plug the line
Old Aug 30, 2005 | 06:01 PM
snatch's Avatar
Well if it's running ok except for that whistling sound of the line being unconnected, try plugging it up and see what happens. If it runs good, leave it. You could also try and find an exploded diagram of the Integra throttle body and see if you can trace the connection to where it used to go.
try http://www.acuraautomotiveparts.org
Old Aug 30, 2005 | 09:02 PM
Bakeoff's Avatar
it probably isn't causing a vaccum leak because the y8 gasket doesn't have a hole there. I would cap it to be on the safe side.
Also, the whistle is probably fro your intake itself, not from this vaccum source.
Old Aug 30, 2005 | 10:57 PM
JDM_EK3's Avatar
Default Re: (Bakeoff)
Capped the one on my CTR Throttle Body, works just fine.
patrEK9
May 19, 2016 03:06 PM
Mike"IAMSLOW"Myers
Aug 2, 2008 10:57 AM
JDMKid71
10
Dec 12, 2005 07:14 PM
Cowtit
Apr 9, 2004 02:52 PM
ITSTOCK
Sep 18, 2003 07:58 PM
