INTAKE-- maybe a problem?
Old Aug 29, 2005 | 05:56 PM
Sprayonsumadidas's Avatar
Default INTAKE-- maybe a problem?
Okay so i just put in a new intake that i bought off of ebay in my Civic LX. Even though I didn't really know what i was doing, you guys were right-- it is fairly easy to put in. I ran into a few problems cuz the one ring wouldn't fit tightly over the seal so I had to manage with some metal wiring... I'll buy the right ring tomorrow.
But anyway-- I was test driving the car and I was at a redlight and as it turned green i took off into first. Then suddenly as I ran up to 4-5k RPM I heard a sucking/popping sound and my engine immediately lost power. That FREAKED me out. I pulled to the side, inspected everything and all the seals were still tight. Even the one that I had to rig with the twine.
Then I took off again, and the car was running fine like before. Any ideas of what could've happened.
Also my RPMs are running higher than usual-- but I'm guessing that's normal since more air means more fuel intake and therefore the engine has to over work. Am I right?
Old Aug 29, 2005 | 05:59 PM
Luserkid's Avatar
Default Re: INTAKE-- maybe a problem? (Sprayonsumadidas)
Are you running a filter? Could have been that you sucked up some water? Could have been anything
Old Aug 29, 2005 | 06:04 PM
vancoland's Avatar
go and buy a k&n filter and be a little more assured...i think you're being way **** about this situation
Old Aug 29, 2005 | 06:06 PM
Default Re: INTAKE-- maybe a problem? (Luserkid)
yea i definately had the filter on-- but i didn't spray any of that oil that's supposed to go on the filter cuz i have no effing clue where to pick it up. I went to pepboys and they sell it only in the package with a new performance filter.
Old Aug 29, 2005 | 06:08 PM
<<go and buy a k&n filter and be a little more assured...i think you're being way **** about this situation >>
haha i tend to like ****, thanks--
no but i'll definately pick up a K&N cone
Old Aug 29, 2005 | 06:12 PM
FalkenSiR's Avatar
WTH you mean by rpms running higher than usual? lol Intake doesn't change your rev limiter...
Old Aug 29, 2005 | 06:15 PM
nota-eg's Avatar
Default Re: INTAKE-- maybe a problem? (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">WTH you mean by rpms running higher than usual? lol Intake doesn't change your rev limiter...</TD></TR></TABLE>
You mean idle?
Take off the filter and look at it. Is part of it missing or is it still intact?
The sucking sound was probably just the air going through the intake. As for the popping sound, I have no idea as to what that was.
Old Aug 29, 2005 | 06:18 PM
AbitAvenger's Avatar
maybe you left something in the intake pipe, or a ghetto ebay sticker was inside and is now inside your motor
just take it off an inspect it, basically common sense bro
bassamillion
Honda Civic (2006 - 2015)
Apr 17, 2018 08:47 PM
Probot
Apr 17, 2007 09:53 AM
1_clean_fg2
Feb 27, 2007 07:00 PM
gEEd93hatch
Jun 30, 2004 10:26 AM
Ben-VTEC
May 25, 2003 05:12 PM
