GSR swap and harness question
Old Feb 25, 2002 | 01:36 PM
EG6-madness's Avatar
Default GSR swap and harness question
I have a question it may be dumb but here goes :-
I am gatheruing info for the GSR into EG motor swap i plan on doing quite soon . Every post I read it seems that every one is talking about repinning their harness to plug into the GSR motor and ECU .
Now I want to know if when you guys buy a swap dont you get the GSR harness ?
isn't the GSR harness made for the GSR motor and ECU ?
so why can't you just plug in the GSR harness into the GSR motor and ECU when doing this swap , instead of re-pinning the EG harness ?
Old Feb 25, 2002 | 02:32 PM
Spade's Avatar
Default Re: GSR swap and harness question (EG6-madness)
Not sure. I haven't actually done a swap yet. Check Hybrid forum.
Old Feb 25, 2002 | 05:57 PM
Short_Shifter's Avatar
I re-pinned my EG harness !
since that is what people have when they did their swaps !
but yeah , that is a good question !
Old Feb 25, 2002 | 06:07 PM
rainforest's Avatar
Default Re: GSR swap and harness question (Short_Shifter)
its just easier that way.
Old Feb 25, 2002 | 06:52 PM
Default Re: GSR swap and harness question (rainforest)
how do you figure that ?
this post actually made me think that , using the GSR harness may actually be easier ( to some extent ) . since everything just plugs in .
the harness then just needs to conected to the power and chassis and where else and your done .
but hey i could be wrong . i also uses the EG traditional harness setup .
it worked for everyone so it should work for me !
Old Feb 25, 2002 | 06:54 PM
B18C-EJ1
Guest
Posts: n/a
You use the GSR harness, but you need to add 3 wires, and move 2 of them to work properly
Old Feb 25, 2002 | 07:26 PM
Default Re: GSR swap and harness question (B18C-EJ1)
so it is ,
Use GSRharness :- either add 3 wires, and move 2
or
Use EG harness :- repin the 6-8 pins ?
Am I correct?
oh ok
kool
Old Feb 26, 2002 | 06:40 AM
92sleepR's Avatar
New User
What they mean is you will need to move a few pins at the ECU plugs to get the IAB and VTEC solenoid to work. It's not that hard to do. there is a flap on the back of the plug that you need to lift up, then use a safety pin and from the plug in end, to depress the tab in the plug body that holds the pin in.
You do not, repeat, DO NOT need the GSR chassis harness, only the harness on the engine itself. The plugs will connect to the chassis harness in the engine bay.
Mike
Old Feb 26, 2002 | 04:32 PM
Default Re: GSR swap and harness question (92sleepR)
So it is easier to use the EG harness ?
Old Feb 26, 2002 | 07:58 PM
B18C-EJ1
Guest
Posts: n/a
Ok, it seems your missing it.
Let's start at the top.
Engine is GSR right?
Use the GSR engine harness and
Keep the stock Hatchback internal wiring
It's plug and play under the hood, but you need to run 3 wires from the engine harness to the ECU, and at the ecu, you need to switch 2 wires.
Does that clear it up for you?
Old Feb 26, 2002 | 08:51 PM
yeah it does
thanks
Old Mar 21, 2004 | 08:01 PM
Ryan C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
Does that clear it up for you?</TD></TR></TABLE>
IAB, v-pressure, and v-spool right?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, it seems your missing it.
what 2 wires are we talking about?
yes i know... "whoa, back from the dead"
Old Mar 21, 2004 | 08:09 PM
mmuller's Avatar
Mad Scientist
Default Re: GSR swap and harness question (Ryan C)
yeah, all you need to do if your using a gsr harness into an eg is:
Move pin a20 to a17
and thats it, if you want evap, you'll have to wire that though
918accord
Apr 17, 2010 08:50 PM
jdm_sai
Feb 16, 2010 05:21 AM
be8teensee1
Dec 9, 2006 09:37 PM
RA101724
Feb 7, 2006 06:06 PM
BLUE EH3
11
Jun 28, 2004 05:16 PM
