Somebody check my injector math here.....
Old Feb 25, 2002 | 01:27 PM
Black R's Avatar
25 Year Member
Default Somebody check my injector math here.....
stock itr injectors = 240cc/min
stock prelude injectors = 290cc/min
celica gts injectors = 310cc/min
dsm injectors = 450cc/min (same harness as honda's)
Now it seems that many feel the stock fuel pump and bigger injectors is better than smaller injectors and pushing higher pressures..... (See hondata for more info on this.)
It seems that when tuning with a vafc, you can only add about 15% fuel before it won't accept a raise anymore..... You can add more on the screen, but you won't actually be raising it any more - simply because of the MAP sensor fooling and crap.
Well, I did some math and it looks like prelude injectors are 20% bigger than the itr injectors. 310's are 29% bigger, and 450's are 87.5% bigger.....
So if you are tuning with a vafc and need to raise to 20% on the wot settings, you could simply keep stock fuel pressure (and save the stock fuel pump) - and adding prelude injectors would enable you to put your vafc back at zero for those points where you needed to add 20% fuel..... Weird, huh?
Old Feb 25, 2002 | 01:33 PM
sgT's Avatar
sgT
Default Re: Somebody check my injector math here..... (Black R)
Incorrect.
The AFC/SFCs are modifying percentage of map voltage not
fuel. So increasing 15% is increasing 15% of whatever the current
voltage is.
Old Feb 25, 2002 | 01:55 PM
Austin's Avatar
Default Re: Somebody check my injector math here..... (sgT)
Incorrect.
voltage is.
Interesting...just learned something new about how those little gadgets work.
Old Feb 25, 2002 | 01:56 PM
AssPenny's Avatar
Default Re: Somebody check my injector math here..... (Austin)
I've always heard that it is better to run a little biger injector and have the vafc or what ever full controll system you are using to turn it down a little. But this might have been for fp, and not injector cycle... <shrug>
Old Feb 25, 2002 | 02:33 PM
sgT's Avatar
sgT
Default Re: Somebody check my injector math here..... (AssPenny)
you can only reduce fuel so much because you are not affecting the fuel maps
at all. You are just telling the ecu to go to another part of the map.
Old Feb 25, 2002 | 02:55 PM
mafay2's Avatar
New User
Then what is the max % you can lean it out with the VAFC?
So the best would be use a FPR to adjust the fuel pressure, then use VAFC to fine tune it at different point.
Old Feb 25, 2002 | 02:56 PM
sgT's Avatar
sgT
Default Re: Somebody check my injector math here..... (mafay2)
max would be -50
that is the method i have been recommending all along.
Old Feb 25, 2002 | 02:57 PM
TypeR0149's Avatar
Steve should I put in my 370cc in before hondata, or will my car run like crap? without the hondata tunning the Fuel?
Old Feb 25, 2002 | 03:02 PM
Black R's Avatar
25 Year Member
.....thanks for the help earlier steve.
Now that basically brings me back to my intended question:
310's are the biggest that the stock ecu can reasonably handle - even with piggyback controls. 290's are bigger than stock too.
I'm wondering if somebody wanted to just slap them on and see what they'll do - what would the outcome be? (at stock fuel pressure, and then of course tuned for fuel psi, gear changes, vafc leaning, timing, etc...)
I'm guessing the 290's will richen up everything across the board. 310's more so, etc... A different route than raising fuel pressure... I guess I chose a bad example - but let's say at 45psi you're still lean with stock injectors. Dropping in 290's will have the same effect as raising fuel pressure by 20%, right? Still at 45psi.....
Old Feb 25, 2002 | 03:07 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Somebody check my injector math here..... (Vegeta)
I actually called RC Engineering when I was deciding on injectors. They say that a Honda ECU can make a car idle (not smoothly) at 30% over stock.
Anything more, and you need some sort of regulator.
TypeR0149's Avatar
Default Re: Somebody check my injector math here..... (shamoo)
anything more, and you need some sort of regulator.
what about a aftermarket fuel pump, is that benifitial?
Old Feb 25, 2002 | 03:13 PM
sgT's Avatar
sgT
I wouldnt put those in without the hondata.
You probably wont need a new pump either unless yours is going bad.
Old Mar 1, 2002 | 08:26 AM
Black R's Avatar
25 Year Member
.....which is 312cc/min. But who makes 312 injectors? So most settle for 310's on stock ecu.....
Old Mar 1, 2002 | 10:31 AM
Mike K's Avatar
or you can look into some Accel injectors if you're on a budget.
They come in packs of 8 injectors(meant for V8), and they are available in hi or low impedance. OBD1 injector clips fit fine.
The 30lb/hr injector set sells for $249.99 at http://www.jegs.com
30lb/hr = 315cc
Other sizes they have are
32lb/hr = 336cc $282.99/pack
36lb/hr = 378cc $389.99/pack
40lb/hr = 420cc $419.99/pack
....just an option to consider. The 315cc ones end up costing $31.24 each.
Old Mar 1, 2002 | 11:09 AM
Black R's Avatar
25 Year Member
Default Re: Somebody check my injector math here..... (Mike K)
30lb/hr = 315cc
Now THAT is what I was looking for!
ooh, I found a link:
http://www.jegs.com/cgi-bin/ncommerc...075&prmenbr=76
Now, where did I leave that formula to convert from lb/hr to cc/min..... *goes to search* .....just wondering what 26lb/hr is. Thanks Mike!
Old Mar 1, 2002 | 11:23 AM
Black R's Avatar
25 Year Member
I found something else that answers a LOT of my questions lately:
http://www.3si.org/member-home/jluci...-fuel-flow.htm
It even gives you some cool calculators for proper injector sizing, etc.....
Old Mar 1, 2002 | 12:18 PM
Mike K's Avatar
I just multiply the lb/hr by 10.5 and that's a good rough estimate.
type B16
Oct 5, 2006 04:06 AM
mannyman
14
Apr 5, 2005 09:10 PM
dazn
Mar 2, 2004 10:17 AM
WONG FRIED RICE
Jul 15, 2003 10:52 AM
mannyman
Jul 23, 2002 08:13 PM
