b16 Hatch running rich
Old Aug 29, 2005 | 12:43 PM
Hatchmonkey94's Avatar
Default b16 Hatch running rich
I have a 94 hatch with a JDM b16 with i/h/e, IM, no cat, GSR ECU.
The car gets really crappy MPG(25) and when vtec cracks I get alot of black smoke. When i bought the car it didnt have an O2 sensor hooked up so I welded a bung and put one in.
Also when I hit around 5k the CEL comes on and stays on. I tried to jump the connector to get the code but none come up. Anyone have any ideas?
-Josh
Old Aug 30, 2005 | 12:58 PM
egsleepercivic's Avatar
get a P30 or a chipped p28, the gsr ecu will always run rich unless chipped
Old Aug 30, 2005 | 05:09 PM
Default Re: (egsleepercivic)
I'm sorry the ecu is chipped, it has a 2 step as well...
-Josh
Old Aug 30, 2005 | 06:36 PM
MenaceL.A.671's Avatar
Default Re: b16 Hatch running rich (SerMonkey92)
isn't it white smoke if your running to rich...?? correct me if im wrong.... cuz i have a chipped ecu and its normal to have it running rich....
Old Aug 30, 2005 | 07:31 PM
torqueMONSTER's Avatar
Default Re: b16 Hatch running rich (m2slsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m2slsvtec &raquo;</TD></TR><TR><TD CLASS="quote">isn't it white smoke if your running to rich...??</TD></TR></TABLE>
white smoke is tranny fluid and steam is coolant...
black smoke is rich
Old Aug 31, 2005 | 06:17 PM
Default Re: b16 Hatch running rich (torqueMONSTER)
Anyone else?
Old Sep 6, 2005 | 08:12 PM
krazie1's Avatar
BANNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torqueMONSTER &raquo;</TD></TR><TR><TD CLASS="quote">white smoke is tranny fluid and steam is coolant...
black smoke is rich </TD></TR></TABLE>
correct and if it was coolant u have the sweet smell coming out of the exhuast
Old Sep 8, 2005 | 05:14 AM
Default Re: b16 Hatch running rich (krazie1)
Will a VAFC help or should i go right for a new ecu?
-Josh
Old Sep 8, 2005 | 05:44 PM
lsvtecracer's Avatar
Default Re: b16 Hatch running rich (Hatchmonkey94)
It really depend on what chip you have in there. Most chip out there are imition and will run rich. The only way to make power is to get your car tune. A vafc will help, but you will still need to jump on the dyno to make adjustment.
Old Sep 8, 2005 | 07:03 PM
Default Re: b16 Hatch running rich (lsvtecracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecracer &raquo;</TD></TR><TR><TD CLASS="quote">It really depend on what chip you have in there. Most chip out there are imition and will run rich. The only way to make power is to get your car tune. A vafc will help, but you will still need to jump on the dyno to make adjustment. </TD></TR></TABLE>
Ok thanks for the help, I actually wound up getting Emanage, good deal i couldnt pass up. Now I just have to find a place to tune it around here, Rochester NY
-Josh
logan.vtec
Aug 29, 2015 05:57 PM
igorka_91
Oct 28, 2009 04:02 PM
Dat1BVtecN
Feb 13, 2009 07:45 AM
jd-em
Dec 6, 2007 12:57 PM
teler86
11
Jul 5, 2006 05:48 AM
