Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Buying brake lines
Old Feb 25, 2002 | 12:16 PM
JeffS's Avatar
Default Buying brake lines
I know this topic has been worn out. I did a search, but nothing came up... (is it me or does the search function not work very well on zeroforum?).
Anyway, I have to order brake lines. I'm looking at these: http://www.optauto.com/webstore/prod...k=yes&dept=859
Is there any reason I shouldn't? or something better? I like the covered lines, but dn't want to spend a fortune on them.
thanks
Old Feb 25, 2002 | 12:18 PM
Drew M's Avatar
New User
Default Re: Buying brake lines (JeffS)
That is about the going rate for brake hoses. Most people run the Goodridge and if I am not mistaken they are $115/set.
Old Feb 25, 2002 | 12:19 PM
Johnny Tran's Avatar
more maintenance......
stick with new stockers jeff. unless you plan on a lot of track duty, maintenance, etc.
Old Feb 25, 2002 | 12:28 PM
JeffS's Avatar
Default Re: Buying brake lines (Johnny Tran)
Well.... the car is being built as a track-only car... I just figured since I had to buy them (the hack that did the engine/suspension pull cut the lines) I'd get something better than stock.
Old Feb 25, 2002 | 12:33 PM
track wh0res r0ck
let me know what the dilly is on the car.........im not too far away if you need a hand or two.
Old Feb 25, 2002 | 12:42 PM
JeffS's Avatar
I just went ahead and ordered the Goodridge lines... I know they'll work, they were in-stock and the others (russell) were backordered.
Chalk this up as another useless thread of mine.
thanks
jeff
Old Feb 25, 2002 | 01:14 PM
MaddMatt's Avatar
I've had trouble with Russel lines in the past. The set I bought from Summit leaked like a sonofabitch on the front. Not surprisingly, they were cheaper than the alternative, Goodridge, which I eventually went with and had no problems at all.
Russel
Goodridge
Old Feb 25, 2002 | 04:56 PM
cvcc130's Avatar
Default Re: Buying brake lines (MaddMatt)
I've had the Goodridge lines on my civic for 4 or 5 years without any problems. I probably have 30+ track events on them. I got them from of all places NOPI. They weren't terribly expensive and work great.
Old Feb 25, 2002 | 05:45 PM
Conechaser's Avatar
Default Re: Buying brake lines (cvcc130)
I keep seeing prices for $110+ for brake lines, my friend just called Auto Rage in Newnan, GA this past summer and got them for $55. I haven't ordered any yet, but i plan to this summer, when i do my brake upgrade.
MugenEg
Suspension & Brakes
10
Jan 18, 2013 08:18 AM
alonsobuiltmotors
Feb 12, 2009 05:56 PM
JellyBeanMobile
Apr 4, 2006 05:24 PM
rainman
Jul 31, 2001 10:03 AM
