staging brake ??
Old Feb 11, 2009 | 06:32 PM
alonsobuiltmotors's Avatar
Default staging brake ??
im about to order this cnc staging brake and i was wondering if i just run lines from the hand brake and t into the rear brake lines. and in this pic it look like theres a line for the front do i just cap it off?
Old Feb 11, 2009 | 06:42 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: staging brake ??
Jeeez I wish the search worked properly. This has been asked and answered a million times.
I'm sure someone will chime in for ya!
Old Feb 11, 2009 | 06:48 PM
ha i forgot about the search sorry last time i look it said it was down
Old Feb 12, 2009 | 02:40 AM
1992Si's Avatar
Last time I checked, the hand brake was cables. I think your going to have a hard time trying to get brake fluid out of them.
Me thinks you better do some more homewrok on how cars are put together before you try and build a race car.
Old Feb 12, 2009 | 03:45 AM
rota92
Guest
Posts: n/a
They make an inline setup, and a rear/front only setup. You'll have to decide what you want, and then read the plumbing diagrams.
Chassisshop.com has them and I think the PDF is there.
Old Feb 12, 2009 | 11:39 AM
yea i spoke too soon i found it on chassis shop.. thanks for the help
Old Feb 12, 2009 | 12:44 PM
grand champ's Avatar
Last time i checked the rear brakes are hydrolic and the e-brake is cable.... A staging brake uses the hydrolic system as "e-brake" if you will for a better hold on the brakes.
Its amazing for preloading at the line!!
Old Feb 12, 2009 | 12:54 PM
lol preload is what im after . do you have this staging brake and did you have to bleed your cable lmao jk
Old Feb 12, 2009 | 12:59 PM
rip94delsol's Avatar
alot of the fast guys still use the hand brake for pre loading. i may not be as fast as them one day but im planning on using the hand brake aswell.
Old Feb 12, 2009 | 01:05 PM
yea i need one cuz i dont even have the orginal e brake when i did my disc conv. the cables where diff so i deff. need this for preloading... any body got any pics of there setups
Old Feb 12, 2009 | 03:35 PM
JBLAZE622's Avatar
i just mounted mine yesterday i'll take pics 2mrw and post em
Old Feb 12, 2009 | 05:38 PM
Tulo's Avatar
What would be the advantage over the stock cable hand brake??
Old Feb 12, 2009 | 05:56 PM
rota92
Guest
Posts: n/a
Line lock capibilities, more holding pressure, and it's made for this whereas the stock e-brake is not. It does work though.
gizzmo222
Jul 24, 2013 08:38 AM
logg_frogg
Mar 8, 2008 02:58 PM
integra15
Mar 1, 2008 05:54 PM
jond
Jun 17, 2001 07:37 PM
