welding brass return on oil pan
I have a home made setup on my oil return and right now the fitting is bolted on but leaks like a mother. I wanted to take it to get it welded today, but i'm using a brass elbow on the outside which can only be brazed to steel i believe? I'm pretty sure that what our oil pans are, but i wanted to double check.
I'm taking it to a welding shop, so i hope the guy knows enough to be careful with it. It got a lil warped when i put it together cause that brass elbow turned on me a few degrees and pushed up on the outer lip of the pan.
I wish moroso's werent soo much bank
Stewie
Welding / Fabrication
Nov 9, 2005 08:38 AM
Sinner
Oct 8, 2004 09:21 AM
