welding brass return on oil pan
Old Aug 29, 2005 | 06:37 AM
Turbo_Mike's Avatar
Default welding brass return on oil pan
I have a home made setup on my oil return and right now the fitting is bolted on but leaks like a mother. I wanted to take it to get it welded today, but i'm using a brass elbow on the outside which can only be brazed to steel i believe? I'm pretty sure that what our oil pans are, but i wanted to double check.
Old Aug 29, 2005 | 06:51 AM
mike1114's Avatar
Default Re: welding brass return on oil pan (MIKE JONES)
yes you need to have it brazed.
Old Aug 29, 2005 | 06:57 AM
Turbo_Mike's Avatar
Default Re: welding brass return on oil pan (mike1114)
Old Aug 29, 2005 | 08:27 AM
iBrandon's Avatar
be sure when they weld it not to warp the pan...i have a couple people i know and their oil pans leak like no other due from warpage..
Old Aug 29, 2005 | 09:10 AM
thehatchninja's Avatar
Default Re: welding brass return on oil pan (Shy Gsr)
JB Weld it. HMT style y0!
Old Aug 29, 2005 | 09:19 AM
Turbo_Mike's Avatar
I'm taking it to a welding shop, so i hope the guy knows enough to be careful with it. It got a lil warped when i put it together cause that brass elbow turned on me a few degrees and pushed up on the outer lip of the pan.
I wish moroso's werent soo much bank
93c1sol
May 20, 2006 08:58 PM
Stewie
Welding / Fabrication
Nov 9, 2005 08:38 AM
Sinner
Oct 8, 2004 09:21 AM
shadow103rd
May 12, 2004 11:55 AM
2SLO
Dec 18, 2003 01:15 PM
