Injector problems PLEASE HELP!
Old Aug 28, 2005 | 09:28 PM
db8sedan's Avatar
Default Injector problems PLEASE HELP!
Well I recently finsih dropping my new motor in 2 days ago and I still cant get it to start...
Car turns over but wont start.
There is spark b/c i've placed a phillips in all plugs to make sure that there is spark.
Ive dbled and tripled checked all plug order wires to distributor and they are correct.
I have fuel, taken off fuel rail and ive seen my injectors spray out fuel when turned over...
I have ground also cuz i checked adn dbled checked...
I think the problems is the injectors, normally its suppose to spray 1 n 3 then 2 n 4. but in my case all 4 are spraying at the same time.
Does anyone know the cause of this? thx in advance...
Old Aug 29, 2005 | 07:04 AM
hondamanwill's Avatar
Default Re: Injector problems PLEASE HELP! (DB8Sedan)
If I'm not mistaking they will spray like that until it sees a rpm signal above 700rpms. You need to take the dizzy off anf rotate it and see if the spray 1342
Old Aug 29, 2005 | 09:14 AM
db8sedan's Avatar
Default Re: Injector problems PLEASE HELP! (hondamanwill)
i did tak eteh dizzy off and tunred it manually it sprayed all 4 at the same time
Thanks
ktecCRV
Honda CR-V & Element
Jan 28, 2018 06:27 AM
OrangeTeggy
Apr 20, 2015 07:33 AM
B16Blake
22
Feb 13, 2010 11:34 AM
A2gt35r
Sep 30, 2007 06:26 PM
db8sedan
Aug 28, 2005 10:16 PM
