Compression #'s on an H23/VTEC??
those numbers sound incredibly high!
which head gasket are you using?
there must be a tiny *** amount of space in the chamber for that much psi haha.
Which OEM pistons did you use? Has the head been milled? OEM headgasket? 300 psi is high, but not bad if you tune it well. Be careful of your ignition timing...
Pirate
Pirate
Those sound high, ive had that same setup only with with a milled block and head and would typically see about 230. If your cam timing is significantly adjusted from stock than those numbers might change but that still sounds high.
