to cam? or not to cam? input plz
Old Aug 28, 2005 | 06:52 PM
SomeDude56's Avatar
Default to cam? or not to cam? input plz
ok so i cam thinking about buying a webber cam for d15 88 rex (dx) for some broader power ranges and was wondering A.can the valves be addjusted with the head still on the block? B. how hard is it to addjust the valves? C. will the valves have to be addjusted indefinately? D. How much ofa power increase am i lookin at here? and befor i hear it i dont have all the cash fora swap...or i would ina heart beat.....wellat least not fora couple years....and im workin on mpfi.....so just bout the bumpsticks plz.
thanks in advance
Old Aug 28, 2005 | 07:09 PM
g-ride-si's Avatar
i dont know bout the cam but im thinkin they prolly arent cheap. If its more than $200 bucks you could easily get a swap. i see tons of low mileage sohc in wrecked cars at the junkyard motor and tranny for fwd cars are $150 here. just my .02
Old Aug 28, 2005 | 07:19 PM
sloweredcivic's Avatar
save you money and swap in a sohc vtec or an si tranny those are far better gains same price ranges
Old Aug 28, 2005 | 08:32 PM
EFRue57's Avatar
Default Re: (sloweredcivic)
yes you can adjust the valves with the head still on the block. it's not hard if you have the right tools and know what you're doing. you never adjust them "indefinately". Chances are if you drive on one particular motor for a long period of time you will have to adjust them again. just out of curiosity, why would you want to readjust them after you already do it once??? doesn't make any sense.
Old Aug 28, 2005 | 09:21 PM
StorminMatt's Avatar
Default Re: (EFRue57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 &raquo;</TD></TR><TR><TD CLASS="quote">just out of curiosity, why would you want to readjust them after you already do it once??? doesn't make any sense.</TD></TR></TABLE>
Because if you drop in a new cam, you are going to break that cam in. This will tend to increase the valve clearance. So after the cam is broken in, it is necessary to readjust the valve clearance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SomeDude56 &raquo;</TD></TR><TR><TD CLASS="quote">ok so i cam thinking about buying a webber cam for d15 88 rex (dx)</TD></TR></TABLE>
Weber cam? Weber makes carburetors. But I don't think they make cams. Do you perhaps mean WEB CAMS?
Old Aug 29, 2005 | 06:44 AM
SomeDude56's Avatar
Default Re: (StorminMatt)
yea.sorry ....long day goin on..ok so how much will it cost to get the valves addjusted?and what tools nessacary to addjust them and how much of a power increase am i lookin at? thanks
Old Aug 29, 2005 | 06:50 AM
g-ride-si's Avatar
adjust them yourself. You will need a 12mm wrench, flathead screwdriver, and a feeler gauge. When you get the cam there should be something that tells u the clearances. I know mine for my b18a are .006 - .007 on ehaust side and .005 - .006 on the intake side. Yours WILL be diff though.
Old Aug 29, 2005 | 12:15 PM
SomeDude56's Avatar
Default Re: (g-ride-si)
thanks........hopes its as easy as it sounds......but still any clue on how much of a power increase im lookin at?
Old Aug 29, 2005 | 12:58 PM
g-ride-si's Avatar
with that motor id say 10-15 maybe
tundra2000
11
May 20, 2011 08:28 PM
Al_90HB
Dec 3, 2010 10:23 PM
D16Cowboy
Apr 26, 2007 01:45 PM
spiceisler
Aug 8, 2002 10:58 AM
W0oT
Oct 4, 2001 10:07 AM
