Symptoms of BAD differential bearings?
Old Aug 28, 2005 | 06:43 PM
crexer's Avatar
Default Symptoms of BAD differential bearings?
I hate to make another thread but this one is a bit more specific and there is no material to find when I did a search on these bearings. Have bad differential bearings #16, would this cause the tranny to make any sounds or noises? When the top one is spun it sounds like a skateboard wheel a bit louder than the rest of the bearings. Im replaces the input shaft bearing but it didnt see to make any noise when spun. So what would bad differential bearings sound like in gear, accelerating or at idle, clutch pushed in or out?
Old Aug 28, 2005 | 07:23 PM
crexer's Avatar
Default Re: Symptoms of BAD differential bearings? (crexer)
gettin desperate here
Old Aug 28, 2005 | 07:39 PM
Jim Truett's Avatar
The diff bearings only turn when the wheels turn. The symptoms of bad diff bearings include whining, grinding, or rumbling coming from the drivetrain while the car is moving, and the pitch or frequency changes with vehicle speed.
Old Sep 1, 2005 | 01:21 PM
roydogg's Avatar
Default Re: Symptoms of BAD differential bearings? (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">The diff bearings only turn when the wheels turn. The symptoms of bad diff bearings include whining, grinding, or rumbling coming from the drivetrain while the car is moving, and the pitch or frequency changes with vehicle speed.</TD></TR></TABLE>
I'm having a sound like it's binding coming from the trans only when i turn. Bought the motor from HMOnline and the car drives fine when I go straight but makes a crazy noise like I have a bad axle when I turn. Axles were already replaced too.
How hard is it to replace the differential?
Old Sep 1, 2005 | 02:05 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote"> So what would bad differential bearings sound like </TD></TR></TABLE>
They can sound kind of like a bad whell bearing. I've seen a couple that only made noise going around sharp turns @ 30mph+.
If you spin any transmission bearings by hand they shouldn't feel rough.
Old Sep 1, 2005 | 02:23 PM
crexer's Avatar
Default Re: Symptoms of BAD differential bearings? (Chiovnidca)
I replaced the input shaft bearing, throwout bearing and pilot bearing, put the tranny back together and it couldnt be any better. Shifts very smooth and is super quiet.
TravisBiggie
Honda Civic (2001 - 2005)
Nov 25, 2012 02:00 PM
canadaek
Transmission & Drivetrain
Nov 6, 2012 02:05 PM
Patman
Jul 30, 2008 08:36 PM
Enzo Speed
Aug 12, 2006 03:56 AM
dyases
21
May 3, 2004 01:42 PM
