do they make hard coolant hoses?
Old Aug 28, 2005 | 06:16 PM
mkinpwrat12g's's Avatar
Default do they make hard coolant hoses?
i was wondering if any company made hard radiator hoses for the 92-95 hatch. if there is a company please let me know and give the website. thank you
Old Aug 28, 2005 | 07:52 PM
lazybrown187's Avatar
Default Re: do they make hard coolant hoses? (nastyeghatch)
there is a company called samco that makes coolant hoses try passwordjdm.com i think they have some on there website
Old Aug 31, 2005 | 12:10 PM
AGS's Avatar
AGS
Def. go with SAMCO Sport radiator hoses. Looks, strength, overall construction is very nice.
Hard rad. pipes would require welding them to the radiator and the necks off the motor.
If you dont weld them to the rad. or anywhere else they will still have silicone/ rubber clamped hoses on each ends so it kind of defeats the purpose.
Old Aug 31, 2005 | 12:17 PM
dawrenn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nastyeghatch &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if any company made hard radiator hoses for the 92-95 hatch. if there is a company please let me know and give the website. thank you</TD></TR></TABLE>
Samco sport is the only way to go
nocturnaldragon's Avatar
Default Re: do they make hard coolant hoses? (AGS)
I wouldn't weld it, it would break because of the vibration, there flexible like that for a reason, the radiator doesn't move the motor does. Just my opinion.
Old Aug 31, 2005 | 12:19 PM
jameskersten1's Avatar
Default Re: do they make hard coolant hoses? (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't weld it, it would break because of the vibration, there flexible like that for a reason, the radiator doesn't move the motor does. Just my opinion.</TD></TR></TABLE>
thats what I was thinking too. Someone prove me wrong if we are both thinking out of line
Old Aug 31, 2005 | 12:23 PM
ROK801's Avatar
Default Re: do they make hard coolant hoses? (jameskersten1)
dont weld it, the welds will eventually crack or youll end up with a crack in the hose itself and then youll have coolant everywhere..
they need to flex.
Old Aug 31, 2005 | 12:24 PM
sockvtec's Avatar
damn i jus bought the factory replacement cause i didnt know bout that ****....well now i know
Old Aug 31, 2005 | 12:28 PM
Default Re: do they make hard coolant hoses? (dawrenn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawrenn &raquo;</TD></TR><TR><TD CLASS="quote">
are those solid metal? they look nice but would need fexable hose to go over them to clamp down which would be perfectly fine. Otherwise I dont know how you'd get them on unless there made of rubber and just look nice.
dawrenn's Avatar
Default Re: do they make hard coolant hoses? (sockvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sockvtec &raquo;</TD></TR><TR><TD CLASS="quote">damn i jus bought the factory replacement cause i didnt know bout that ****....well now i know </TD></TR></TABLE>
The Samco Sport hoses are $100+
Old Aug 31, 2005 | 12:30 PM
dawrenn's Avatar
are those solid metal? they look nice but would need fexable hose to go over them to clamp down which would be perfectly fine. Otherwise I dont know how you'd get them on unless there made of rubber and just look nice.</TD></TR></TABLE>
lol, they are not metal. I think they are silicone.
Old Aug 31, 2005 | 12:32 PM
ok, I dont see the advantage over stock then.
Do they last longer or something?
Old Aug 31, 2005 | 12:36 PM
dawrenn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">ok, I dont see the advantage over stock then.
Do they last longer or something?</TD></TR></TABLE>
The SamcoŽ Sport Hose Kits are designed to replace original equipment for a wide range of vehicles. Superb integrity and superior performance reduce the risk of component failure and that enables higher temperatures and pressures to be maintained with complete confidence.
Standard silicone hoses are not suitable for carrying fuel/oil. High temperature, fuel/oil, high pressure etc.
Old Aug 31, 2005 | 12:40 PM
RedDC5's Avatar
Cant go too wrong with OEM, always my opinion i guess...
ILcrxsi1
Mar 29, 2007 03:14 PM
EGdrop6
Jul 20, 2006 07:19 AM
missionaryrider
Jun 21, 2005 09:19 PM
plusONE jboy
Dec 25, 2004 11:23 AM
B18EG6
May 5, 2003 11:36 PM
