Audio Setup Question
Old Aug 28, 2005 | 04:06 PM
metpage's Avatar
Default Audio Setup Question
Hey guys I got a 97 4 door Accord and have the following audio equipment getting installed (when i get the money):
Alpine DVA-9860 DVD
Gathers In-Dash Screen
Eclipse 8362 Components - Front
Eclipse 8122 12" DVC - x2 Subs
Eclipse 6213 - 2 Channel 1000watt Amp (for subs)
Eclipse 33230 - 2 channel 130watt Amp (for speakers)
Any ideas on what kinda wiring grade i need for this install and how much of it? Also anyone in the DC area know of a reputable shop that will install this setup for a decent price? I got quoted $1300 from Excessive Audio in Rockville because i also needed them to build a custom box for the subs as well. Any suggestions would be helpful.
Old Aug 28, 2005 | 08:42 PM
PLAGUED_DB7's Avatar
Default Re: Audio Setup Question (metpage)
No Cap???? You need at least a 1.5
4 Ga. wire is cool...Its only 2300 watts... Get the THX Rca cables too..
Old Aug 29, 2005 | 11:26 PM
romoracing's Avatar
Default Re: Audio Setup Question (PLAGUED_DB7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLAGUED_DB7 &raquo;</TD></TR><TR><TD CLASS="quote">No Cap???? You need at least a 1.5
4 Ga. wire is cool...Its only 2300 watts... Get the THX Rca cables too.. </TD></TR></TABLE>
Where did you get 2300 watts? He has only 2 amps. One is 130 watts and the other is 1000 watts. Thats only 1130 watts.
Why dont you install it yourself? Save yourself about 1000 dollars. Go to a audio shop or someplace online and get a harness that connects to your stock harness and you dont have to cut wires. The speakers are a plug and play thing. Okay you might have to cut out the door panels to make them fit but its simple.
But hey if you want to get it done by a pro. there more the happy to take your money. I would
Also you should get a cap and 4 aug. will be fine. Get a box from a store around you or online to save some money:
http://www.crutchfield.com/S-W...B2124
http://www.crutchfield.com/S-W...e_all
Also why almost pay 50 to 100 dollars for some rca cables when normal ones do the same and they only cost 20-30 dollars at the most?
Another thing when you go get it installed see what the guy(installer) has done before. If hes new ask for someone to help him. Just my 2 cents!
Optiks.
Audio / Security / Video
15
Mar 1, 2018 11:57 PM
ITR EG
22
Aug 23, 2006 09:31 PM
pete griffen
Nov 3, 2005 01:24 PM
civichatchb18c
Dec 19, 2004 08:47 AM
integra99blue
Sep 24, 2003 07:19 AM
