wiring 2 4ohm DVC subs for 2ohm load
Old 04-18-2005, 03:29 PM
Optiks.'s Avatar
Default wiring 2 4ohm DVC subs for 2ohm load
hey guys i have a question
i have 2 kaption 12" dual voice coil subs that are 4ohm
i need to wire them for 2ohm so i can get the best performance from my amp which is 2 ohm stable and about 656 watts rms
On crutchfield the only load options are 1 ohm or 4 ohm
how can i load it for 2 ohm?
heres the almost completed setup
Old 04-18-2005, 03:37 PM
fcm
Old Fart
fcm's Avatar
Default Re: wiring 2 4ohm DVC subs for 2ohm load (Optiks.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Optiks. &raquo;</TD></TR><TR><TD CLASS="quote">hey guys i have a question
</TD></TR></TABLE> Like they said 1 ohm or 4 ohm and one more 8 ohm 94
Old 04-18-2005, 03:38 PM
vigor5spd's Avatar
You cant do it with that setup because the subs are dvc. You would need 2 more subs.
Old 04-18-2005, 04:55 PM
Optiks.'s Avatar
Default Re: wiring 2 4ohm DVC subs for 2ohm load (vigor5spd)
theres no way i can put 2 4ohm resitors in there to simulate 2 more subs or something
Old 04-18-2005, 05:24 PM
fcm
Old Fart
fcm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Optiks. &raquo;</TD></TR><TR><TD CLASS="quote">theres no way i can put 2 4ohm resitors in there to simulate 2 more subs or something </TD></TR></TABLE>No point, the resistance of a VC changes elec. to sound, the resistance of a resistor will convert the elec. to heat, you would also need some big resistors, [volt wise] I think, droping the load in half will, [on paper] double the output of the amp and that would give you 3dB more output, I bet you can get that out of the box just by bracing, sealing and mounting the box solidly to the car. 94
Old 04-18-2005, 05:44 PM
zumiez007's Avatar
Default Re: wiring 2 4ohm DVC subs for 2ohm load (fcm)
Here are your options for what you've stated.
Get one more subwoofer and you can get it to 2.67ohms.
Old 04-18-2005, 06:26 PM
Optiks.'s Avatar
Default Re: wiring 2 4ohm DVC subs for 2ohm load (zumiez007)
thats not an option, i just built the box yesterday
Old 04-19-2005, 12:19 PM
adrian1281's Avatar
consider buying 2ohm dvc subs...
Old 04-20-2005, 08:00 PM
iNteGraz92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Optiks. &raquo;</TD></TR><TR><TD CLASS="quote">thats not an option, i just built the box yesterday</TD></TR></TABLE>
.... not our fault you have a mismatched amp and subs
you can either get another amp, or like adrian1281 said, get 2ohm dvc subs. those are your ONLY options. saying 'that's not an option' is not an option. simple as that.
Old 04-20-2005, 09:54 PM
dc24me's Avatar
just because it's a 2 ohm stable amp doesn't mean you'll need to run it at 2 ohms. with a 4 ohm load, the amp will run cooler, be less of a strain on your cars electrical system, less distortion and last longer. it will be more reliable that way.
Old 04-20-2005, 11:11 PM
HavokB18's Avatar
Just build a bigger ported box and run it at 8 ohm
Old 04-21-2005, 03:27 AM
Optiks.'s Avatar
Default Re: (HavokB18)
problem solved, i just bought a 1 ohm amp and rewried them for 1ohm
Old 04-21-2005, 08:08 AM
fcm
Old Fart
fcm's Avatar
Default Re: (Optiks.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Optiks. &raquo;</TD></TR><TR><TD CLASS="quote">problem solved, i just bought a 1 ohm amp and rewried them for 1ohm</TD></TR></TABLE> LOL....... nothing is impossible, It just costs more 94
Old 04-21-2005, 11:54 AM
nsxxtreme's Avatar
The resistor idea made me laugh .
What amp did you get?
Old 04-21-2005, 12:12 PM
Optiks.'s Avatar
Default Re: (nsxxtreme)
we are on a budget, 1000w rms tsunami 1ohm amp, not really 1000w rms but close
the first person to comment on the setup was my neighbour 5 houses down
"can you turn that down? my whole house is shaking"
fat bitch will love when i get my 15"s
Old 03-01-2018, 11:57 PM
Andrew Bol's Avatar
This is how I wire 2 4ohm dvc subs to a 2ohm load. You can do it the check it with a multimeter then no longer listen to the know it all people that have nothing better to do than argue back and forth rather then give ya a simple opinionated answer. Sorry drawing isn' artist quality.
xBlackMikex
Audio / Security / Video
04-18-2007 05:59 AM
Orpheus1985
07-31-2005 04:11 PM
ChronicFrogs2004
05-05-2005 08:49 PM
ablack934doorcivic
04-19-2005 12:33 PM
JTCdudeman
10
01-20-2003 09:40 PM
Quick Reply: wiring 2 4ohm DVC subs for 2ohm load
