hondata problem
Old Aug 28, 2005 | 12:34 PM
Jago's Avatar
Default hondata problem
I have a p28 with a stage two witohut data logging setup on an h22. It was tunned about two or three weeks ago and has been just fine except for ocasionally while driving the light on my interface box has gone out and the rev limit became lower. This goes away if I flip the ignition on and off. The ligt comes bace on and it runs fine. I figured this was probably just a problem with the interface cable.
My new problem is that when accelerating in first gear from a slow speed the cel comes on shortly and then goes out. When in first at full throttlethe car will not go into vtec and the rpm is limited two about 6k. but when on the higway it vtec works fine and it will rev to the set revlimit.
So far I have just Re burnt the chip and nothing changed. Any help that can be given on this issue will be greatly appreciated
Thanks
boostin4door
May 1, 2007 06:23 PM
papa_smurf
Nov 24, 2002 02:56 PM
torran
Aug 18, 2002 12:16 PM
