b18c eg running really slow??? need help!!
i have a 95 dx with a b18c(gsr), for some reason my eg is running stupid slow, my first and half of second gear is really slow takes vtec a while b4 it comes to life to life.. i took it to the trax and it ran a consistant 15.9s.. and i know dohc can do alot better then that.. at first i thought i was a shitty driver but i had three other driver drive it and still ran close to my time.. plz help.. i dont even know where to start.. to check for the problem, sometime it'll pop a cel 43 (which is fuel system) but i cant seem to find the problems
Modified by civ_tek at 1:28 PM 8/28/2005
throw it on a dyno dont go by the seat of your pants dyno. what ecu? have a buddy check it with a wideband o2 to see if you are running lean and have a fuel system problem
im running a p72, also vtec is starting to stutter, i checked all the ground and rechecked the wiring and everything checks out, now with the cel43 it comes on occassionally, whenever it feels like it
yea gsr wiring harness, it shouldnt matter what wiring harnesses right? as long as its vtec compatible?? i hope it doesnt have a leak gasket or anything, and plus how can i tell if its leaking?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civ_tek »</TD></TR><TR><TD CLASS="quote">yea gsr wiring harness, it shouldnt matter what wiring harnesses right? as long as its vtec compatible?? i hope it doesnt have a leak gasket or anything, and plus how can i tell if its leaking?</TD></TR></TABLE>
What would make you think it has a leak?
Is it burning or consuming lots of oil?
Have you looked for leaks?
Compression test?
Compression test?
need to start with the basics..
check if your timing is correct, if you're getting poor or below average gas mileage your timing may be off, this can cause a huge loss in power
maybe your plugs are going bad
maybe you have a leak somewhere in your intake manifold that's causing a lean/rich condition
maybe you need to clean the sensors on the i/m
your o2 sensor may be bad
etc.
etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civ_tek »</TD></TR><TR><TD CLASS="quote">yes vtec is wired, i can hear vtec engaging</TD></TR></TABLE>
are you sure its not the secondary butterflys you hear?
check to see if the knock sensor is plugged in or even wired into the ecu. i had the same prob. my hatch would only run 15.1 and found out that the knock wasnt hooked up now im running 13.7
Touch
11
Nov 22, 2007 10:23 AM
