error code 22 with disabled vtec oil pressure switch
I have disabled the vtec oil pressure switch( the d6 cable goes from the ecu directly to the ground). But I have also error code 22. What could it be?
Here is my setup:
ported d16y8 head
105300 cam
1mm ferea bigger valves
zex valve springs
d16z6 IM
hondata gasket
b16 tb
d15b2 block
walbro 255lph
Here is my setup:
ported d16y8 head
105300 cam
zex valve springs
d16z6 IM
hondata gasket
b16 tb
d15b2 block
walbro 255lph
i've never heard of grounding the pressure switch pinout and not getting a cel. With certain ecu's you can ground the - wire from the pressure switch to the engine, but the hot wire (D6) has to be connected. What kind of 'trouble' does the pressure switch make?
1SikEagle
Apr 11, 2009 01:02 PM
whophlungpoo
10
Oct 1, 2006 10:52 AM
tinkerbell
Jan 1, 2005 08:00 PM
