swaps
I have a 93 honda civic hatch aut. I swaped the head with a v-tec head same year and I also put the same ecu but I have one concern after everything I feel that the car holds down on the start it takes long for it to get its speed I would like to know what's wrong with it help...
If you had a non vtec motor and do did a mini-me swap then you are goind to need a vtec ecu, I think that where your problem it going to be at. Hope I'm right and that this helps.
get a p28 ecu, make sure u wired the VTEC solenoid and pulled the oil jet.
https://honda-tech.com/zero...age=1
look at that for more info, (if you havent already)
Joshua_Missey
Honda Civic (2001 - 2005)
Jun 28, 2018 12:35 PM
92civichatchvx
12
Jan 29, 2011 11:27 PM
