stripped thread on squirters!! (block)
Old Aug 27, 2005 | 07:48 PM
11SECEG's Avatar
Default stripped thread on squirters!! (block)
I have a gsr block building for a friend of mine but the thread on the block for one of the squirters is stripped. Does anybody here knows what tap I need for it? If re-threading didn't work, can I use inserts? Is it possible to weld it to build some material inside the hole and then re-thread it? The bolt is already kinda loose when i put it in the hole..
Thanks in advance!!!
Old Aug 27, 2005 | 10:34 PM
DC2 to AP2's Avatar
Default Re: stripped thread on squirters!! (11SECEG)
you running forged internals? if you are, you can just weld them all up and increase oil pressure at the same time. just a option..
Old Aug 27, 2005 | 10:38 PM
11SECEG's Avatar
Default Re: stripped thread on squirters!! (imola-red dc2)
Oem ctr pistons the set up im doing is gsr block with ctr pistons
Old Aug 29, 2005 | 03:52 AM
808 NA1's Avatar
That size and pitch is a tough one to find. Bump for an answer.
Old Aug 29, 2005 | 05:10 AM
b18bturbo's Avatar
re tap it to 1.8npt and be done with it the plug thread is very hard to find out normally so just retap it and it works mint
Old Aug 30, 2005 | 01:46 PM
11SECEG's Avatar
Default Re: stripped thread on squirters!! (b18bturbo)
thanks
Old Sep 1, 2005 | 02:00 PM
DavidR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">re tap it to 1.8npt and be done with it the plug thread is very hard to find out normally so just retap it and it works mint </TD></TR></TABLE>
Not really, I found a tap at an industrial supply in Dallas. I tried putting them in my B20, but it didn't quite work. I still have the tap though, case anyone is interested in it?
Old Sep 1, 2005 | 02:30 PM
b18bturbo's Avatar
Default Re: stripped thread on squirters!! (DavidR)
i think you misunderstood me i meant finding a plug to work stock is what is bitch to find 1.8npt taps are everywhere
mtownek9
Oct 5, 2007 09:02 PM
kidd_drastic
Nov 11, 2005 12:39 PM
strictlyallmotr
May 25, 2005 07:41 AM
Linus_E
Mar 23, 2005 04:52 AM
IMPORTant Si
Oct 28, 2004 01:44 PM
