axles keep going out???
Old Aug 27, 2005 | 05:39 PM
t3to4e's Avatar
Default axles keep going out???
After installing a new full face clutch into my 94 integra my axles went out i though it was because i hit a big bump but now im leaning toward it being something else because i got new axles from auto zone and two weeks later they are bad i can go under the car and grab the head of the axle that clicks into the tranny and onto the intermediate shaft and wobble it almost like they arent clicked into the diff but they are
im out of ideas please any fedback would be great
Old Aug 27, 2005 | 08:42 PM
rhd type r's Avatar
Default Re: axles keep going out??? (t3to4e)
what part of the axle is broken, is it a cv joint, or is it the teeth on the end.
Old Aug 28, 2005 | 01:58 AM
t3to4e's Avatar
Default Re: axles keep going out??? (rhd type r)
you physicaly cant see its broken you can feel it when you drive and when the car is parked and lifted i can go under and grab the housing off the shaft by where is clicks into the tranny i can move it all around
Old Aug 28, 2005 | 12:30 PM
t3to4e's Avatar
well after looking around my engine bay today i think i may have found out what's wrong the passenger side mount that has the 3 bolts that thread into the tranny only have 1 on the other two were missing and the mount was cocked to the side a lil
i hope this is whats causing the axles to go out
Old Aug 29, 2005 | 02:14 AM
t3to4e's Avatar
anyone???
Old Aug 29, 2005 | 02:40 AM
racecarpete's Avatar
Most likely you have already caused damage to the inner collar. It is now become kind of ovalized and will cause the axle to work it's way out. I have the same issue, passenger axle keeps popping out. I'll be getting an LSD soon to fix the problem.
Old Aug 29, 2005 | 06:29 AM
t3to4e's Avatar
Default Re: axles keep going out??? (SilverCivic2k)
mount now has all 3 bolts and i will be getting new axles so hopefully they wont go out anymore i dont see how the diff could be messed up from that because in my case the axles are staying locked into the diff. I think the uneven balance due to the lack of bolts was tilting the tranny back and there for causing the axles to spin uneven and making them ware out
any other fedback would be great
Modified by t3to4e at 5:39 PM 8/29/2005
Old Sep 1, 2005 | 11:15 AM
t3to4e's Avatar
wow i though i might get some more input
Old Sep 1, 2005 | 09:56 PM
turbocrx2.1's Avatar
yea that mount should deffinitly be your prob i had a drive side mount with only one bolt in it other one must of viberated out and every time i made a left i busted an axle i must of went through at least 5 or 6 axles before realizing that the mount was missing a bolt so i put a new one in and never had a problem again
Old Sep 2, 2005 | 12:37 PM
t3to4e's Avatar
well fixed bolt and axles went out again cool huh who knows maybe i should just blow it up
Old Sep 4, 2005 | 10:42 AM
t3to4e's Avatar
any more ideas?
Old Sep 7, 2005 | 11:32 AM
t3to4e's Avatar
no-one
Old Sep 17, 2005 | 01:27 PM
t3to4e's Avatar
bump
Old Sep 18, 2005 | 10:57 AM
Hecdosage's Avatar
It sounds like you need an LSD to fix the problem or a new differential. You might think not but the clearences are vital on these cars. Hope that helps
"prepare for the worst situations and be humble with the least"
By hecdosage
Old Sep 19, 2005 | 07:37 AM
t3to4e's Avatar
Default Re: axles keep going out??? (Hecdosage)
yea im gonna just get a new tranny
Old Sep 20, 2005 | 05:12 AM
Hecdosage's Avatar
My friend had the same problem and he got it fixed for 250.00 his differential was messed up and now he is running again.
Old Sep 20, 2005 | 06:47 AM
t3to4e's Avatar
yea 3rd gear grinds and pops out sometimes so ill just go for new tranny
any other info would be cool
Old Sep 20, 2005 | 08:40 AM
Hecdosage's Avatar
Yeah those are the synchros that grind from mishifts. They're like 185.00. If you do get a new tranny don't throw away the one you have because that can be fixed easy. What kind of tranny is it anyways
Old Sep 20, 2005 | 09:04 AM
t3to4e's Avatar
its a ls but i think its a 96 but it will be for sale cheap when i get a new one if your interested
cfoamcvc
Feb 15, 2007 07:17 AM
hondatuner20
Mar 19, 2006 04:36 PM
SimplyTron
Dec 6, 2005 05:50 PM
Reelizmpro
11
Sep 8, 2005 02:08 PM
95lstegman
Apr 12, 2005 02:38 PM
