The low-down on spark plugs
Old Feb 25, 2002 | 08:28 AM
HPilot's Avatar
New User
Default The low-down on spark plugs
A BIG Thanks goes out to John at NGK for his help.
B16A spark plugs are PFR6L-13
The NGK Iridium plug equivalent is BKR6EIX-11
(3764 stock number)
The NGK V Power plug equivalent is BKR6E-11 (2756 stock number)
John advised that the Iridium plug will work well with an MSD ignition, even though it has a fine wire diode. The v power plug does provide some added performance, but is equalled by the Iridium plug. Non-resistor plugs can be used, but are really only for heavy drag racing applications because of the RFI interference that can be created. Resistor plugs are fine for a street car with mild track use. Heavier race use can cause the resistor to break. He advised that the stock ecu can be burned out from the RFI that non-resistor plugs create. Most spark plugs are the projected type in late model cars. Projected, meaning that the plug is elongated, placing the diode deeper into the cylinder. Non-projected are more for 12-16:1 compression engines, and are applicable to racing applications.
The NGK spark plug wire part number for the B16A is HE-64 or 9775. MSD does not make a wire direct fitted for the B16A, I was using the wires for the integra.
The iridium plugs are $6.40 from sparkplugs.com and I got the NGK Power wires (blue ones 7mm) from them as well for $51.95. Wires were cheaper than Summits price. Monarch (sparkplugs.com) is 1-888-800-9629.
edit: 51.95 for Power Wires, not the OEM's
[Modified by HPilot, 10:13 PM 2/25/2002]
Old Feb 25, 2002 | 09:58 AM
Mike K's Avatar
Default Re: The low-down on spark plugs (HPilot)
OEM Spark plug wires for B18C/B16A
$46.94
p/n 32722-P30-000
Old Feb 28, 2002 | 04:46 AM
HPilot's Avatar
New User
Here's some more helpful info on id'ing and choosing the right plug. you must have adobe to read the page. http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
123Four
Sep 22, 2007 03:28 PM
zakiu
Honda S2000
17
Apr 23, 2007 09:04 AM
Calean007
May 9, 2005 07:04 PM
Jcup315
Apr 18, 2005 06:08 PM
Casey
Mar 19, 2002 07:00 PM
