B&M FPR Problem
Old Aug 27, 2005 | 01:43 PM
smash fascism's Avatar
Default B&M FPR Problem
I have a 94 EG with a B16 in it, I have an AEM high flow fuel rail with stock injectors. My problem is that when ever I try to set the pressure with just the fuel pump primed, as soon as I start the car it jumps up. Ill set the pressure at 38PSI and as soon as it is started it will jump to 42PSI. is there something im doing wrong? is the FPR shot?
Old Aug 27, 2005 | 02:17 PM
ThatsMyEG's Avatar
Default Re: B&M FPR Problem (smash fascism)
i always adjust mine when the cars on. It needs pressure to get a correct setting...
Old Aug 27, 2005 | 02:19 PM
fasthatchb18c1's Avatar
yeah do it while the car is running, also it will run a little richer when cold than warm
Old Aug 27, 2005 | 02:59 PM
Padawan's Avatar
Darth ModerVader
You should be adjusting the regulator with the engine running and the vacuum hose disconnected.
Old Aug 27, 2005 | 07:29 PM
I've done that, with the car running I can turn the adjustment screw all the way up and down and it won't make any difference.
Old Aug 27, 2005 | 07:30 PM
Also, sometimes when I unhook the vacuum off from the regulator it doesn't even make pressure increase. Weird??????
Old Aug 27, 2005 | 09:49 PM
Bump for some bedtime help.
Old Aug 28, 2005 | 05:58 AM
Mista Bone's Avatar
D Tranny Guru
what fuel pump???????
Sounds like the typical B&M stuck partially open. Buy a AEM or Aeromotive.
Old Aug 28, 2005 | 06:12 AM
I have a walbro 255lph fuel pump. B & M have a problem with sticking open?
Old Aug 28, 2005 | 07:05 AM
Mista Bone's Avatar
D Tranny Guru
yep!!!!!!!!!
Lucky yours is only stuck part open. If it stick wide open, all the fuel is bypassed back to the tank, interior will reek of gas, car losses about 90% of it power.
I got stranded in a hotel parking lot, 2 days before a import race. If this would have happened while running the 85 ZEX shot, motor would had died, explosively!!!!!
Old Aug 28, 2005 | 07:14 AM
When I put the motor in at the beginning of summer after installing the fpr and a bunch of other stuff, it was real sluggish and it drank gas like crazy. Should I buy an aem fpr?
Thanks for the help.
Eric
Old Aug 29, 2005 | 01:14 AM
hhhmmm well I have had a B&M for 3 years and not one problem.
Old Aug 29, 2005 | 02:13 AM
BoOstedEM1's Avatar
Default Re: (fasthatchb18c1)
I think they were implyin that they are known to stick..not all of them will stick...just his is partially stuck...I had one for 1 yr..and was fine.. then i switched setups all together..
Old Aug 29, 2005 | 11:14 AM
Mista Bone's Avatar
D Tranny Guru
I had mine for 4+ years before it acted up, just a warning to keep your eyes open.
Old Aug 30, 2005 | 03:34 AM
Default Re: (Mista Bone)
Will do then, this is the first time iv heard of this.
jman86
Nov 7, 2024 12:19 PM
superturboprelude
Jul 10, 2007 06:04 PM
dunkd
Apr 6, 2006 07:47 PM
seen4ever
Aug 5, 2004 06:59 AM
