IS my CLutch gone??
i was driving home today, and my clutch engaging point seem to be higher, and it start slipping and it hard to go into gear. when i got home it won't go into gear anymore. i just put in the clutch couple days ago, it is a EXEDY stage 1 Racing clutch. it been only like 200 Miles on the clutch. when the car is off the gear goes in fine. i don't think it the tranny problems. it either the clutch or maybe i need to adjust the clutch pedal because the clutching breaking in? i need Input in this, please help! i need my car running again on monday for school
oop i post in the wrong area, i got a 97 honda prelude.
.oop i post in the wrong area, i got a 97 honda prelude.
You said it goes into gear fine when the car is off, but not when it's running. Seems like 9 times out of 10 it has been because something is messed up with the clutch. Despite the fact it's new, maybe it's not tight enough, maybe something broke and you got a bad clutch.
check your clutch fluid and make sure that you did not get an air bubble in your clutch line. if it is good then pull the clutch and take a look
