ignition key (WTF!)
Old Aug 27, 2005 | 09:16 AM
loup05's Avatar
Default ignition key (WTF!)
ok i dont no wat the problem is. I have a 95 accord LX and when i try 2 start the engine i sometimes have a hard time turning the key. i dont kno wat it is. i have to turn the wheel to the left a lil and turn the key at the same time. It works sometimes but not really. it always gets stuck as if it wasnt even the key for this car. I had 2 keys i lost the original which kinda wasnt any difference to the one i have now i dont kno if its the key itself or something else wat do u guys think?
Old Aug 27, 2005 | 09:25 AM
Diego Dangers.'s Avatar
mines like that to, the whee locks itself.
Old Aug 27, 2005 | 09:36 AM
P_Adams's Avatar
Default Re: ignition key (loup)
I'm trying to wrap my head around this topic 'cus it's really simple but hard to discribe.
when you shut the car off make sure you're not trying to turn the steering wheel. After shutting off the engine there may be some residual energy trying to turn the wheel back, so it binds against the lock mechanism. that binding keeps the key from turning until you relieve that pressure.
You'll note that the wheel springs a little past (in the other direction) once you release the key.
This isn't uncommon when you do a lot of street parallel parking. You know, that kind of parking which requires a lot of turning, turning, turning, some swearing and more turning.
P
Old Aug 27, 2005 | 09:40 AM
deserthonda's Avatar
after so many uses keys wear as do cylinder locks tumblers, have the DEALER cut u a new key, spray some lube inside ignit switch cylinder , if still hard it might be time to replace the ignit switch assembly
Old Aug 28, 2005 | 12:33 PM
loup05's Avatar
Default Re: ignition key (deserthonda)
around how much do the dealers charge to get me a new key. and wont spraying any kind of liquid solutioin damage the ignition switch?
Old Aug 28, 2005 | 04:28 PM
cost to cut a key at dealer should be around 4 to 6 dollars... and spraying something like wd40 will not damage the switch
Old Aug 29, 2005 | 03:01 PM
LookingForVTEC's Avatar
it called a steering wheel lock. Just turn you wheel to the left or to the right before you turn the key. That is just the way honda's are!!!
Old Aug 29, 2005 | 03:45 PM
AFAccord's Avatar
Default Re: (LookingForVTEC)
i would spray some powdered graphite like locksmiths use... just my 2 cents.
Old Aug 30, 2005 | 06:48 AM
loup05's Avatar
Default Re: (AFAccord)
alright man thanks for the input greatly apreciated
Old Aug 30, 2005 | 01:25 PM
twistedbydezign's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AFAccord &raquo;</TD></TR><TR><TD CLASS="quote">i would spray some powdered graphite like locksmiths use... just my 2 cents.</TD></TR></TABLE>
not sure what this stuff is but i would go along with this and spray the specific stuff that they sell for locks that they keys have a hard time going in and out of, not just wd40 or something
Old Aug 30, 2005 | 03:00 PM
Jxi8s2k's Avatar
actually...if you have a 1998+ honda..you gotta pay about 70 dollars for a new key. there is like some damn chip in the key. if you copy it from like home depot or whatever, you can use that key to unlock/lock the doors, but you won't start the engine.
Old Aug 30, 2005 | 04:09 PM
Default Re: (buffalo wings)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buffalo wings &raquo;</TD></TR><TR><TD CLASS="quote">
not sure what this stuff is but i would go along with this and spray the specific stuff that they sell for locks that they keys have a hard time going in and out of, not just wd40 or something</TD></TR></TABLE>
i will only reccomend something that i have used myself and works without causing any damage .......i have sprayed a **** load of ignitiopn switches with wd40 throughout my years working with hondas and never had a problem ,
Alice Jones
Honda CR-V & Element
18
Jan 26, 2018 03:30 PM
wwzjd
Feb 11, 2015 09:00 PM
maryk2121
Jun 25, 2013 11:35 AM
crxforum
17
Feb 6, 2007 07:15 PM
dc2go
May 23, 2005 10:33 AM
