wiring experts...
anybody know which wire is the vtec wires? i do not want to wire it from the ecu... i was told the del sol is already wired for vtec meaning i can just splice a wire from the sockets next to the battery correct?
uhhh... not all del sols are wired for vtec... only the si... wich is the single cam vtec.... or the del sol vtec wich is the b16...
if you look here... it will show u what u need....
https://honda-tech.com/zerothread?id=1171263
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">uhhh... not all del sols are wired for vtec... only the si... wich is the single cam vtec.... or the del sol vtec wich is the b16...
https://honda-tech.com/zerothread?id=1171263</TD></TR></TABLE>
dude... where the heck did you find this lol. anyway, i have a p08 ecu (d15b ecu sohc VTEC) my set up is a jdm d15b sohc vtec motor in a del sol S.
i'm still using the same wire harness form the automatic d15b7 (94 sohc non-vtec ecu)
i have 2 sockets... a green like 1 (2 wires) and a regular looking one (1 wire). with a total of 3 wires. i only see 2 below?
can i use this guide here:
Modified by idriveadelsol7 at 3:23 AM 8/28/2005
i'm still using the same wire harness form the automatic d15b7 (94 sohc non-vtec ecu) i have 2 sockets... a green like 1 (2 wires) and a regular looking one (1 wire). with a total of 3 wires. i only see 2 below?
rewerbcrx
Feb 19, 2008 08:42 AM
97grnrs
Dec 18, 2005 02:01 PM
GSR_deLsOL
May 4, 2004 10:52 PM
