Trunk wont open!!!!
Old Aug 26, 2005 | 09:58 PM
VIS250P's Avatar
Default Trunk wont open!!!!
I washed my car at car wash place. ANyhow Im going to pop the trunk open and it wont opened.. All I can hear the electric motor went whirring. Do anyone have problem open the trunk on the Integra? Please help
Old Aug 26, 2005 | 10:02 PM
purehonda's Avatar
Default Re: Trunk wont open!!!! (py)
Yeah mine does the same, it would work every once in a while until it finally just quit all together. That motor has stripped gears i believe, and it retails for like $50-60 something. Im cheap so I just got used to using the key.
Old Aug 26, 2005 | 10:07 PM
VIS250P's Avatar
Default Re: Trunk wont open!!!! (purehonda)
PM SEND
Old Aug 26, 2005 | 10:18 PM
Kicker773's Avatar
next time u get a chance to open it.. spray some lubricant on there and it should b ok...
Old Aug 26, 2005 | 11:10 PM
AntonioH's Avatar
Mine does the same thing. It started a couple of weeks ago. I just use the key now. Does anyone have a spare?
Old Aug 26, 2005 | 11:13 PM
k e v i n's Avatar
Default Re: (AntonioH)
God dammit!!! I can't get my crack outta the trunk!!!
Old Aug 26, 2005 | 11:54 PM
Mythias's Avatar
Default Re: (k e v i n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k e v i n &raquo;</TD></TR><TR><TD CLASS="quote">God dammit!!! I can't get my crack outta the trunk!!!</TD></TR></TABLE>
Old Aug 28, 2005 | 08:34 PM
IntegraXTR's Avatar
mine did the same too. people with tegs (98+) have that problem from what i've heard.
i just use my key haha. you turn the key and hold it till it pops, then yank the trunk
Old Aug 28, 2005 | 10:03 PM
TypeRPaul's Avatar
"I smoke rocks Joe Rogan"
Old Aug 29, 2005 | 04:47 AM
mehdiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py &raquo;</TD></TR><TR><TD CLASS="quote">Yeah mine does the same, it would work every once in a while until it finally just quit all together. . .... I just got used to using the </TD></TR></TABLE>
Same here
Old Aug 29, 2005 | 05:57 PM
ITR764's Avatar
Default Re: Trunk wont open!!!! (mehdiR)
damn, mine does it and i thought i was the only one....
Old Aug 29, 2005 | 06:01 PM
Mythias's Avatar
Now that I think about it, I actually had this problem on my 2000 ITR. For some reason the latch/locking mechinism got stuck. Sometimes the latch would get jammed after I opened the trunk and I couldnt get it closed again. Back then I was lazy and jsut took it to the dealer. 45 minutes and $70 it was fixed.
Old Aug 29, 2005 | 06:06 PM
yellow blur's Avatar
Default Re: Trunk wont open!!!! (mythias)
Mines busted also.
Old Aug 29, 2005 | 08:48 PM
98 Spec R's Avatar
Mine is broken also. The part to fix it is $90 I think I will just use the key.
Old Aug 29, 2005 | 08:59 PM
Tweakmeister's Avatar
Default Re: Trunk wont open!!!! (98 Spec R)
mine's gone too
there should be a recall with this many problems.
Old Aug 29, 2005 | 09:03 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mythias &raquo;</TD></TR><TR><TD CLASS="quote">Now that I think about it, I actually had this problem on my 2000 ITR. For some reason the latch/locking mechinism got stuck. Sometimes the latch would get jammed after I opened the trunk and I couldnt get it closed again. Back then I was lazy and jsut took it to the dealer. 45 minutes and $70 it was fixed.</TD></TR></TABLE>
yea on my 2000 PY it does the same thing. I just have a habit now of making sure the lock clicks back before closing it each time.... o well
Old Aug 30, 2005 | 02:54 PM
Renegade's Avatar
Default Re: Trunk wont open!!!! (totsie7944)
same here.
GuCCi_GSR
May 20, 2007 11:43 AM
ROMOeg93
10
Apr 6, 2007 02:05 PM
GuCCi_GSR
Sep 10, 2005 12:43 AM
VIS250P
Aug 27, 2005 12:52 AM
Denny
Sep 5, 2003 02:19 PM
