camber kit question
Old Aug 26, 2005 | 09:35 AM
too much vtAK's Avatar
Default camber kit question
when buying an adjustable control arm set, do i need to buy a new ball joint, or can i reuse the stock ball joint???
any help would be greatly appreciated.
Old Aug 26, 2005 | 01:09 PM
(puma)'s Avatar
Default Re: camber kit question (dailybeater)
i think you should be fine with the stock ball joints.
Old Aug 26, 2005 | 01:12 PM
nub.96ek's Avatar
Default Re: camber kit question (_B_Series_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _B_Series_ &raquo;</TD></TR><TR><TD CLASS="quote">i think you should be fine with the stock ball joints.</TD></TR></TABLE>
Old Aug 26, 2005 | 01:48 PM
khme12's Avatar
If you are using your stock ball joint, you would need to have it pressed out of the stock piece by a shop or a hydrolic press and then pressed onto your new camber kit.
Old Aug 26, 2005 | 03:13 PM
ETA_Si's Avatar
Default Re: camber kit question (khme12)
Im with him
Old Aug 26, 2005 | 03:16 PM
zeronine's Avatar
same here bud!!!
Mr. Em1
Suspension & Brakes
Jun 6, 2008 01:15 PM
Options
Aug 6, 2006 09:15 PM
EJ8 GSR-T
Feb 19, 2005 11:41 AM
Civichatch27
May 31, 2004 12:43 PM
wildstallion
Feb 6, 2003 08:18 PM
