Taking off Inside door panel??
Old Aug 26, 2005 | 08:41 AM
MtbikingKing's Avatar
Default Taking off Inside door panel??
how do u take off the inside door panel???? so far i just pulled it off but thers one thing holding it on and i dono what it is.?? Im trying to install some new speakers.
Old Aug 26, 2005 | 08:49 AM
accordselux's Avatar
Me Gusta History
Default Re: Taking off Inside door panel?? (MtbikingKing)
Depends on what year car.
Mine is a 98-02, you have one screw in the little cup you use to close the door with, one in the door handle, plus a lot of little clips. Look around for any other screws and clips you might have missed.
Old Aug 26, 2005 | 10:06 AM
fw190bvi's Avatar
Default Re: Taking off Inside door panel?? (accordselux)
take out anything that bolts into the door panel. not sure about 4th/6th gens, but i know on teh 5th's you have to unsnap the little plastic trim that covers the wiring for the mirrors, and remove a screw in there or something...it was a PITA when i took mine off, but once you can do it once, its easy
Old Aug 27, 2005 | 07:01 PM
BLKFLSH's Avatar
Be carefull not to break the little plastic clip holding the door handle to the rod. If it is broken the rod will never stay in the hole.
Old Aug 27, 2005 | 07:07 PM
HondaAccordTdR's Avatar
Default Re: Taking off Inside door panel?? (BLKFLSH)
yeah, just undo the screws, then pop off all of the plastic clips and hold the door into place. Before you go yanking off the door as a whole make sure you disconnect the windows, door locks and the little door light. You dont have to take off the thing that covers the mirror but i would recommend it because mine is all scratched up from when i forgot to take it off.
Hyard24
Audio / Security / Video
Jan 16, 2008 08:12 AM
todd.ludwig
May 1, 2006 02:27 AM
inty2511
Mar 25, 2004 05:27 PM
NtegraRacR05
Sep 15, 2003 06:57 PM
sicilian2k1
Aug 21, 2001 03:52 AM
