Door Speakers
Old Jan 11, 2008 | 09:24 PM
Hyard24's Avatar
Default Door Speakers
Does anyone know if there is any way to install door speakers in a 97' Accord without taking the whole panel off? I haven't found any screws and the screen doesnt seem to be able to pop off.
Old Jan 11, 2008 | 10:41 PM
bseriescrxsi's Avatar
Default Re: Door Speakers (Hyard24)
if the door is the same as the 94,95 models the speaker casing does pop right off
Old Jan 12, 2008 | 06:41 AM
The-Kid's Avatar
Default Re: Door Speakers (bseriescrxsi)
Yea the casing comes off with force. But when putting it back in, it may be hard to get it back to factory flush....
Old Jan 13, 2008 | 12:03 AM
aasaa666's Avatar
thats true. I'd rather just remove the door panel. note: in the process of removing the door panel you may break the screw cap for the inner door handle, and the part in the middle of the panel where you put your hand on to swing the door, and the clips that hold the panel to the door.
Old Jan 13, 2008 | 10:05 PM
YeuEmMaiMai's Avatar
speaker is screwed into the door remove 3 screws and pop the panel off and you are good to go. takes about 15 mins tops
Old Jan 14, 2008 | 01:06 PM
hometheaterman's Avatar
Default Re: (YeuEmMaiMai)
Don't force that speaker grill off as it's screwed in from the inside of the door. You have to take the door panel off to remove the screws from the back side that hold that grill on.
You basically have to take the door panels off.
Old Jan 15, 2008 | 11:56 PM
jgojohn's Avatar
Default Re: (hometheaterman)
94-97 Accord Manual says you have to remove the panel
Old Jan 16, 2008 | 08:12 AM
Hyard24's Avatar
Default Re: (jgojohn)
Thanks guys, glad I didn't try to force that thing off
todd.ludwig
May 1, 2006 02:27 AM
Si_Prelude
Dec 12, 2005 06:32 AM
snake01
Jan 11, 2002 09:06 PM
onyx00
Sep 5, 2001 12:44 PM
sicilian2k1
Audio / Security / Video
Aug 21, 2001 03:52 AM
