is a stock zc good for boosting
it has pretty high compression but if you get a larger head gasket it should lower the compression and it could be capable of alot... I'm still thinking about boosting my zc but I'm not sure I need money so I might need to sell it as you can see... stock I would say no though upgrade fuel management of course then just make sure everything else is good to go and then maybe...
i say yes!!!!!
im running one right now
turbo edit
450cc injectors
HF manifold
BMC adapter plate
Fabricated all my charge pipes and Down pipe
Stock internals stock fuel pump
10 PSI
turbo edit
450cc injectors
HF manifold
BMC adapter plate
10 PSI
eh i would have to say somewhere aroun 185 or so. never dynoed it and never really ran it with this set up.
the last ghettofied set up i had got me high 14's but then again im not a good driver.
lunaticracer21
May 7, 2007 10:17 PM
Grandhustleman86
16
Jan 13, 2007 09:12 PM
