tranny problem
Old Aug 25, 2005 | 08:23 PM
Koyoloeor's Avatar
Default tranny problem
I put a new motor in my car because the clutch went bad and that gave me a reason to go ahead and put a lower milage motor in it. I put in an exedy stage one clutch and put the same tranny back on it. (the clutch was actually gone to the point that the car wouldnt go into gear or move) I got it all put back togeather and the car would not go into 2nd, 4th or reverse. I pulled the tranny back off and checked to make sure the clutch was on right and i also bought another tranny that i for sure know was good. I put it all back togeather and i still have the same problem...any body know what the problem could be?? any help would be greatly appreciated.
Old Aug 25, 2005 | 08:27 PM
EL Vap133's Avatar
Default Re: tranny problem (Koyoloeor)
What kind of engine/tranny did you have and what kind of engine did you buy? What clutch did you buy and for what application?
Old Aug 25, 2005 | 08:42 PM
Koyoloeor's Avatar
Default Re: tranny problem (EL Vap133)
I had a 97 civic dx...i put in another d16y7 motor and another dx tranny. the clutch i bought was exedy stage 1 for a d series motor.
Old Aug 25, 2005 | 10:01 PM
Toxidomask's Avatar
did you bleed your clutch? if its hydrolic? mayb you should try, doesnt hurt. Besides that the stage 1 is a bit heavier than the OEM, could messed up you worn clutch MC and slave, either or.
boostedhks
26
Aug 26, 2008 09:32 PM
tony88crx
Jun 21, 2005 06:37 PM
phatstyles
May 1, 2005 05:54 PM
Synergy001
Dec 7, 2003 09:42 AM
